Hello, everyone. I'm fairly new to overclock.net and thought I'd share the build I've just completed. This is my first full computer build so I'm open to any suggestions/ criticisms. P.S. Sorry in Advance for the bad picture quality and terrible lighting. I'm working on getting a place set up for some better photos. Alright, now the components:
Case: Corsair 350D
Power Supply: Corsair AX 860i
Motherboard: Asus Z87 LGA 1150 Maximus Gene VI Micro ATX Motherboard
CPU: Intel Core i7 4770k
RAM: 32 GB Corsair 2133 MHZ
GPU: EVGA GTX 780 Ti Superclocked
Storage: 2 x Samsung EVO 500 GB SSD in Raid 0
Storage: 1 x WD Black 4TB HDD
Fans: 4 x Corsair 120mm SP High Performance and 1 x Corsair 120mm AF Quiet Edition
Now for the watercooling components:
Reservoir: Bitspower Multi-Z 150 x 60 mm Tube Res
Pump: EK D5 Pump
CPU Block: EK CSQ Supremacy Clean
GPU Block: EK Acetal Full Cover Waterblock w/ Backplate
Radiators: 2 x Alphacool 30mm Slim Radiators
Fittings: All fittings are Bitspower's Matte Black Fittings
Coolant: Mayhems Pastel Red
I really wanted a tube reservoir in this build as I love the way they look. However, including this into my build forced me to sacrifice on some performance and also may look a bit crammed. Opinions? Anyways, I'll post the pictures below. Also, if you guys are interested, I will post some benchmarks tomorrow to give you guys a good idea of how the system is running overclocked. All in all, I'm very happy with this as its my first complete PC build.
UPDATE: I took some (hopefully) better pictures. The last ones were washed out and blurry.
