Considering Thermalright Archon - Overclock.net
post #1 of 7 Old 05-22-2011, 07:48 AM - Thread Starter
733mhz
iSeries's Avatar
Quoted: 0 Post(s)
Liked: 19
I've just upgraded my case from a tiny MATX case to a CM 690 II Advanced, which has opened up a whole world of costly upgrade opportunities lol. Currently my 1055t is being cooled by an Akasa Venom, and I'm considering replacing this with a Thermalright Archon. I was wondering what kind of temp / noise improvement I could expect over my current solution? Also, I was wondering if the Archon can be installed with the fan facing downwards, blowing air towards the top of the case?
iSeries is offline
post #2 of 7 Old 05-23-2011, 03:48 PM
Overclocker in Training
saint19's Avatar
Quoted: 0 Post(s)
Liked: 178
Hi and welcome to OCN.
The Archon is one of the best cooler in market, but usually the best performance is archived blowing air from front to the back side of the case.
saint19 is offline
post #3 of 7 Old 05-23-2011, 10:25 PM
Fan Man
Bing's Avatar
Quoted: 0 Post(s)
Liked: 28
Yes, its possible for the HS orientation with the fan blowing upward, check the Archon Club, I posted few pics there.
Tested both orientations and in my case I got better result than blowing backward.
Bing is offline
post #4 of 7 Old 05-24-2011, 03:02 AM
333mhz
SigmaGT's Avatar
Quoted: 0 Post(s)
Liked: 0
and what about the sound?
is it louder than a CNPS9900Max?
I'm thinking of changing it for a Archon or a Silver Arrow because mine is pretty lousy once you get past 1200rpm....and the CPU temps doesn't drop that much
SigmaGT is offline
post #5 of 7 Old 05-24-2011, 09:19 AM
Overclocker
Quoted: 0 Post(s)
Liked: 2
Gigabyte GA-MA78LMT-US2Hs socket and ram slot is too close
i think it's can't be install bottom-to-top
my Sabertooth is looks possible, but need standard sized memory
erasure is offline
post #6 of 7 Old 06-17-2011, 03:51 AM
Commodore 64
solmer88's Avatar
Quoted: 0 Post(s)
Liked: 0
hi
i saw you bought the Archon and have CM690II. Does it fit well in the case? Or do you use open case?
solmer88 is offline
post #7 of 7 Old 07-15-2011, 06:51 AM
Commodore 64
Quoted: 0 Post(s)
Liked: 0
YES! Thermalright Archon fit's in my Coolermaster CM690, so i think that CM690 II is not so diferent.thumb.gif
Locos is offline
