Intake fan in a 5.25 bay (warning - graphics) - Page 5 - Overclock.net
post #41 of 328 Old 07-05-2011, 10:12 PM
*cough* Stock *cough*
AgentHydra's Avatar
Quoted: 0 Post(s)
Liked: 100
I've got two 70mm fans running on 5V ziptied into two 5.25" bays in my CM 590.
Don't think it does anything but I've got nothing better to do with the fans biggrin.gif
A 7950 will probobly be about the same as a 7950.
2 Million+ Folding at Home points  Chimp Challenge Participant X4
AgentHydra is offline
post #42 of 328 Old 07-05-2011, 10:45 PM - Thread Starter
Data Beats Theory AirGoes Where You Push It
ehume's Avatar
Quoted: 0 Post(s)
Liked: 1372
That's why I tried my two 80mm fans in there. Their LED's were pretty, though.
I actually bought the fans for their controllers: At $4.99 for fan + controller, I thought it was a great deal. No use for either half now, though. frown.gif
ehume is offline
post #43 of 328 Old 07-06-2011, 09:45 AM
MexGT's Avatar
Quoted: 0 Post(s)
Liked: 27
All of you guys that are interested in a 120mm fan in the 5.25 bays, should consider this
http://www.newegg.com/Product/Produc...-019-_-Product
Tht cage even comes with that 120mm fan, not all of us will like the color but hey, its hidden and its another fan anyway ! lol ...
cheers.
MexGT is offline
post #44 of 328 Old 07-06-2011, 10:06 AM - Thread Starter
ehume's Avatar
Quoted: 0 Post(s)
Liked: 1372
ehume is offline
post #45 of 328 Old 07-06-2011, 12:15 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 52
Originally Posted by ehume;14124670
Nice price on that Xiggy box.
But putting in our own fan is more fun.
Exactly. I believe Mountain Mods already got posted earlier in this same thread but here. It's a 5.25" adapter for 120mm fan mount. I'd much much rather buy this than that xiggy box. Of course, I haven't found a 140mm mount like that, and it's a little bit pricey for what a styrofoam mod can do.
a pet rock is offline
post #46 of 328 Old 07-06-2011, 02:25 PM
_02
Tick tock, life is gone
Quoted: 0 Post(s)
Liked: 195
I had no room, so I used a cage+fan to mount my 3 drive RAID array in the bay.
I wouldn't have bothered a DIY project for that when the elegant solution was $25.
Otherwise, yeah.
_02 is offline
post #47 of 328 Old 07-06-2011, 04:42 PM
3.5ghz
SirWaWa's Avatar
Quoted: 0 Post(s)
Liked: 39
fan still mounted towards the front
the home made internal method still wins
SirWaWa is offline
post #48 of 328 Old 07-08-2011, 12:02 PM
PC Gamer
DaXxJaPxX's Avatar
Quoted: 0 Post(s)
Liked: 73
Originally Posted by ehume;14119385
This is when I had only two slots free:
where the hell did u optical drive go then? lol
1 Million+ Folding at Home points
DaXxJaPxX is offline
post #49 of 328 Old 07-08-2011, 01:16 PM - Thread Starter
ehume's Avatar
Quoted: 0 Post(s)
Liked: 1372
Back then the ODD was in the third 5.25 slot and the IO panel in the 4th 5.25 slot. I switched them. Now the half-length IO panel is on top of the ODD, which leaves me three slots open behind the IO panel, even though there are only two slots open in front.
Just a better utilization of space.
ehume is offline
post #50 of 328 Old 07-13-2011, 05:42 PM
Case Modder
rprice06's Avatar
Quoted: 0 Post(s)
Liked: 32
Just saying xigmatek makes a great HD enclosure for that area and its cheap u could install this and move the drives or just use it behind some mesh drive panels.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817996019&Tpk=xigmatek%20hard%20drive
rprice06 is offline
