Hyper 212+ Temps - Overclock.net
post #1 of 9 Old 10-16-2011, 10:38 AM - Thread Starter
PC Gamer
GuardianDuo's Avatar
Quoted: 0 Post(s)
Liked: 59
Just wondering, what temperatures should I be getting with my Phenom II x4 @ 3.6GHz (stock 1.35v, but vdroop brings it to around 1.32v at load) and an ambient of 28C?
I recall Core Temp saying I hit a max of 54C during BFBC2 once, and that seems pretty high compared to other people. Using stock 212+ TIM, btw.
/31% ASUS|8% AMD|4% EVGA|4% nVidia|21% Cooler Master\
|8% SeaSonic|2% Antec|7% Samsung|7% Logitech|8% Corsair|
GuardianDuo is offline
post #2 of 9 Old 10-16-2011, 10:43 AM
Networking Nut
Quoted: 0 Post(s)
Liked: 219
how much tim did you use?
1 dot in the center isnt nearly enough for the 212+, it has a extremely rough base
3 lines between the heatpipes work best
ffejrxx is offline
post #3 of 9 Old 10-16-2011, 11:00 AM
pel
Commodore 64
pel's Avatar
Quoted: 0 Post(s)
Liked: 1
Phenom II x4 @ 3.6GHz, just changed multiplier to 18, 1.392v at load, ambient around 25C or mby a bit less now, after 60 min of prime95 52C, yes seems a bit high but as long as it doesn`t reach 55+ should be ok, also i belive after some decent OC might go even lower.
pel is offline
post #4 of 9 Old 10-16-2011, 11:03 AM
2.4ghz
El_Capitan's Avatar
Quoted: 0 Post(s)
Liked: 105
The Hyper 212+ only comes with one fan in a push config. You'll get better results if:
1. You apply the TIM correctly.
2. You put another fan in there in a push/pull.
3. You maximize your case flow (basically add a side fan to push air in, have the rear and top fans push air out.
El_Capitan is offline
post #5 of 9 Old 10-16-2011, 11:20 AM
Overclocker
Zeek's Avatar
Quoted: 0 Post(s)
Liked: 24
I'm using a 212+ with 2 fans in push pull config and these are the temps I am getting at 4ghz under 100% load with prime95
GuardianDuo likes this.
Zeek is offline
post #6 of 9 Old 10-16-2011, 11:23 AM
Intel Overclocker
importflip's Avatar
Quoted: 0 Post(s)
Liked: 111
I always use this method.
steam: anonyflip
origin: importflip
importflip is offline
post #7 of 9 Old 10-16-2011, 11:28 AM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 59
I used the two line method with a dot in the middle because I had some excess TIM stuck to the front of the plunger-thing.
It should have been a good application, as I didn't lift up the HSF after letting it contact the CPU.
Also, I don't know how to read Hardware Monitor, but does that say 30C ambients with 54C load???
I've got a side fan for intake for my 460, two bottom intakes, a front intake, two top exhausts, and a back exhaust in my 690II Advanced. All fans are 120mm, 3 are stock, 2 are Sickleflows, and 2 are Antec TriCools.
And my 212+ is just Push. What do you guys use to control fan speed? SpeedFan?
I'm currently using the Asus Qfan thing in BIOS. It should be ramping up to 100% when it reaches over 50C.
post #8 of 9 Old 10-16-2011, 11:32 AM
Overclocker
Zeek's Avatar
Quoted: 0 Post(s)
Liked: 24
You must have used the TIM wrong or placed the cooler wrong. Maybe you got a bad CPU. My ambient is 30C and Im getting 53C @ 4ghz. When I played BF3 beta temps were only around 48C. Try to remove the cooler and remove all paste and redo the install and you could also get another fan for push/pull if you have the money.
Zeek is offline
post #9 of 9 Old 10-16-2011, 11:35 AM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 59
Ehh, probably the TIM then.
How do I get the old TIM out of the cracks when cleaning the 212+ base?
Also, could one of my heatpipes be cracked/leaking?
