Coolermaster Hyper 212 Evo and Corsair Vengeance on P8Z68 Board? - Overclock.net
post #1 of 7 Old 10-29-2011, 02:02 AM - Thread Starter
PC Gamer
apav's Avatar
Quoted: 0 Post(s)
Liked: 10
Hey guys, I bought all my parts for my first build besides the cpu cooler... I don't plan on overclocking (maybe a little later) and I want my case cooler and quieter, so I feel like the Hyper 212 Evo does that very well:
http://www.newegg.com/Product/Produc...82E16835103099
My question is, will it fit? I got Corsair memory which is VERY tall with their heatsinks:
http://www.newegg.com/Product/Produc...82E16820233180
I'm using a ASUS P8Z68-V board. A lot of people said (with the Hyper 212 Plus) that it doesn't fit in their first memory bank, but is it different with the Evo, even if I raise the fan higher? Also is there any performance difference if I use the 2nd and 4th memory channels instead of the 1st and 3rd (if I can't fit the Corsair in the first slot)?
Thanks guys
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
apav is offline
post #2 of 7 Old 10-29-2011, 02:05 AM
PC Gamer
Azuredragon1's Avatar
Quoted: 0 Post(s)
Liked: 43
you can raise the fan higher or do what i did and put your ram in the 2nd and 4th slots and no there's no performance difference if you did that
Azuredragon1 is offline
post #3 of 7 Old 10-29-2011, 03:56 AM - Thread Starter
PC Gamer
apav's Avatar
Quoted: 0 Post(s)
Liked: 10
Hmm I'll give it a look. I don't think the fan can go high enough...
Also is there any indication on the heat sink as to which way the heat is being exhausted?
apav is offline
post #4 of 7 Old 10-29-2011, 07:01 PM - Thread Starter
PC Gamer
apav's Avatar
Quoted: 0 Post(s)
Liked: 10
Anyone know if putting the RAM in the 2nd and 4th slots will differ in performance from the 1st and 3rd?
apav is offline
post #5 of 7 Old 10-29-2011, 07:07 PM
Fan Man
denial_'s Avatar
Quoted: 0 Post(s)
Liked: 39
denial_ is offline
post #6 of 7 Old 10-29-2011, 07:08 PM
3.5ghz
rdfloyd's Avatar
Quoted: 0 Post(s)
Liked: 92
Most motherboards recommend the 2 & 4 slots first. My Sabertooth uses 1 & 3 for the second set of DIMMs.
If Logitech and Corsair's support teamed up, the world would divide by zero.
So I gathered from this thread that the OP is a raging homosexual and he owns an alienware...
rdfloyd is offline
post #7 of 7 Old 10-29-2011, 07:12 PM
Fan Man
denial_'s Avatar
Quoted: 0 Post(s)
Liked: 39
denial_ is offline
