CM Hyper 212+ 1 OR 2 fans? - Overclock.net
post #1 of 38 Old 11-04-2011, 03:42 PM - Thread Starter
Tronic707x's Avatar
Quoted: 0 Post(s)
Liked: 5
Whats the difference between 1 and 2 fans on this cpu cooler tempature wise.
Tronic707x is offline
post #2 of 38 Old 11-04-2011, 03:45 PM
733mhz
mrteddy's Avatar
Quoted: 0 Post(s)
Liked: 7
Send a message via Skype™ to mrteddy
maybe 1 degree
ran my hyper 212+ with an extra CM Sickle flow 2000rpm with the stock one and maybe VERY little difference, IMO not worth the extra noise
LOVIN LYFE ATM
mrteddy is offline
post #3 of 38 Old 11-04-2011, 03:46 PM - Thread Starter
Tronic707x's Avatar
Quoted: 0 Post(s)
Liked: 5
Its not noise i care about my stock cooler is at 6000rpm all the time, i care about the money.
post #4 of 38 Old 11-04-2011, 03:48 PM
333mhz
theHipsterMO's Avatar
Quoted: 0 Post(s)
Liked: 1
I found it helped me out on my old 1090t, idle it was only a 1c or 2c drop but at load it was around a 5c drop which helped me stay in the low 40's. If you don't have a fan controller you can always use the SpeedFan application to control the rpm, just bump it up when you need it. Good luck mate!
theHipsterMO is offline
post #5 of 38 Old 11-04-2011, 03:50 PM
WaterCooler
Nickw's Avatar
Quoted: 0 Post(s)
Liked: 31
i just installed mine, got 29C on stock i5- 2500
1 fan ( stock one )
Nickw is offline
post #6 of 38 Old 11-04-2011, 03:51 PM
733mhz
mrteddy's Avatar
Quoted: 0 Post(s)
Liked: 7
LOL, 6000RPM on the stock fan? the stock fan only goes to 2000RPM
well i guess u could get the sickle flows, there relatively cheap compared to other fans, i forgot about OCing, a second fan would help noticeably more on load than idle
LOVIN LYFE ATM
mrteddy is offline
post #7 of 38 Old 11-04-2011, 03:54 PM - Thread Starter
Tronic707x's Avatar
Quoted: 0 Post(s)
Liked: 5
While gaming my temps go up becuase im at 4ghz and it usually is at 60c and up and my fan reaches 6000 rpm but it drops as the temp goes down. 3500rpm is the max i could put it to whenever im below 45c
post #8 of 38 Old 11-04-2011, 04:04 PM
PC Gamer
Epyon415's Avatar
Quoted: 0 Post(s)
Liked: 11
What are your temps now? Installed mine last week and made additional system changes:
-removed unused expansion slot covers
-added bottom case intake fan
noise levels are around the same and my temps shifted as such:
OLD (covers on, no fan): idle 36'C, Load 54'C
Current: idle 27'C, Load 47'C (average gaming is around mid 30's, unless my gpus kick up to 85'C)
This is all with just 1 fan, if your temps are bad I would look at changing things up internally in your case, but I dont think the extra fan will change much. Let us know what you end up doing and results!
Epyon415 is offline
post #9 of 38 Old 11-04-2011, 04:26 PM - Thread Starter
Tronic707x's Avatar
Quoted: 0 Post(s)
Liked: 5
my temps are at like 43c idle and it can go to 80c at load but i stopped
i should be getting this fan today or tomorrow, i hope to see good results!
post #10 of 38 Old 11-04-2011, 04:38 PM
733mhz
mrteddy's Avatar
Quoted: 0 Post(s)
Liked: 7
sorry i dont understand, are u using the stock fan that came with the cooler?, because the MAX speed of that fan is 2000rpm, NOT 6000rpm
LOVIN LYFE ATM
mrteddy is offline
