Arctic Freezer 64 Pro - Overclock.net
post #1 of 19 Old 10-03-2006, 10:48 PM - Thread Starter
4.0ghz
Lyoko's Avatar
Quoted: 0 Post(s)
Liked: 90
This is kind of big... It has a gray pad where it comes in contact with CPU, i think this is thermal paste. I also have arctic silver 5.
Any guides on how to apply arctic silver 5 on a cpu?
Lyoko is offline
post #2 of 19 Old 10-03-2006, 10:52 PM
4.0ghz
dex100's Avatar
Quoted: 0 Post(s)
Liked: 129
remove the thermal pad (nail polish remover or any strong consentrate alcohol will get it off) then place a bb (or half a grain of rice) size bit of AS5 on the center of the heatsink (or the processor itself, it doesn't really matter that much) then firmly seat the heatsink. Although I've heard that the MX1 (the stuff that comes stock on it)that is even better than AS5 (plus it has no metal parts to it so it doesn't conduct electrcity at all) so I would suggest you just leave it on
dex100 is offline
post #3 of 19 Old 10-03-2006, 10:55 PM - Thread Starter
4.0ghz
Lyoko's Avatar
Quoted: 0 Post(s)
Liked: 90
Oh, because this "Arctic Silver 5" Sounds so popular nowadays lol... THX. I am going to make ramsinks for this GeForce 5500FX from my old sempron 3400+ stock heatsink. The fan I can somehow mount on card.... This Silver 5 stuff is a good adhesive and can hold a ramsink right? (After i cut the huge silver spreader into four equal parts)
Lyoko is offline
post #4 of 19 Old 10-03-2006, 11:05 PM
4.0ghz
dex100's Avatar
Quoted: 0 Post(s)
Liked: 129
no, i wouldn't use AS5 for that its not like a glue at all and won't hold the ramsinks on. There is a product by Arctic cooling that is an adhesive probably called Arctic adhesive, let me check
http://www.newegg.com/Product/Produc...82E16835100005
dex100 is offline
post #5 of 19 Old 10-03-2006, 11:08 PM
Now Available in Orange
Fishie36's Avatar
Quoted: 0 Post(s)
Liked: 751
Actually that is not a pad, it's a paste called MX1 and is just as good as AS5. Don't touch it
Fishie36 is offline
post #6 of 19 Old 10-03-2006, 11:11 PM
Multi-Quote King
Quoted: 0 Post(s)
Liked: 845
The RAM sinks that came with my Zalman VF-700Cu stayed well with AS5. I thought AS5 wasn't supposed to dry up, but it did on the RAM sinks
"I just talk the way I see things... If that's offensive to you... I'm sorry; you're a loser." - Michael Savage
"But you would be amazed by how many people think that the only reason to have a computer is to play games, and that playing games is all that anyone with a computer does." - dangerousHobo
The Hundred Gunner is offline
post #7 of 19 Old 10-04-2006, 01:15 AM
frostbite's Avatar
Quoted: 0 Post(s)
Liked: 230
Yeah the MX-1 paste is great, leave it on
Roads? Where We're Going, We Don't Need Roads!
Overclock.net 10 Year Member
frostbite is offline
post #8 of 19 Old 10-04-2006, 01:19 AM
The Odd Mod
Quoted: 0 Post(s)
Liked: 1172
I also used AS5 to stick RAM heatsinks to my video cards.... on my previous X850 they even stayed on during shipping
1 Million+ Folding at Home points
Chozart is offline
post #9 of 19 Old 10-04-2006, 05:02 AM - Thread Starter
4.0ghz
Lyoko's Avatar
Quoted: 0 Post(s)
Liked: 90
*starts sawing* WISH ME GOOD LUCK!
Lyoko is offline
post #10 of 19 Old 10-04-2006, 05:16 AM
1.7ghz
mtuccio's Avatar
Quoted: 0 Post(s)
Liked: 17
Leave the MX1 paste on the cooler, clean off your CPU good, and just install the freezer 64.
Dont use both though since you already have thermal paste on the Freezer.
mtuccio is offline
