will corsair h80 support AFB1212GHE-CF00 5200rpm fans? - Overclock.net
post #1 of 15 Old 04-19-2012, 06:53 PM - Thread Starter
technofied's Avatar
Quoted: 0 Post(s)
Liked: 10
http://www.newegg.com/Product/Product.aspx?Item=N82E16835213001
ill be getting two for push/pull on corsair h80.but each one takes in 30 watts, 60 in total will the h80 fan controller support this.
technofied is offline
post #2 of 15 Old 04-19-2012, 06:55 PM
Case Modder
GREG MISO's Avatar
Quoted: 0 Post(s)
Liked: 66
I dont think so. but the nzxt sentry mix can handle 30 watts per channel if you need a good controller.
V-Dubbin since nineteen thirty somethin!
Air-cooled
Arizona Overclockers Club
"The only club that overclocks with an ambient of 120f"
1 Million+ Folding at Home points
GREG MISO is offline
post #3 of 15 Old 04-19-2012, 07:29 PM - Thread Starter
technofied's Avatar
Quoted: 0 Post(s)
Liked: 10
what happens if i connect the fans to the directly to motherboard, will they run at max all the time, what i want is for them to automatically increase in speed as the cpu gets hotter and not the other temps just like the stock h80 fans
post #4 of 15 Old 04-19-2012, 07:34 PM
Case Modder
GREG MISO's Avatar
Quoted: 0 Post(s)
Liked: 66
If your motherboard can handle that much power through the header it would run at full but i really dont know enough about motherboards to say if it could handle that. Good luck
Air-cooled
post #5 of 15 Old 04-19-2012, 07:35 PM
WaterCooler
Quoted: 0 Post(s)
Liked: 38
I think you may have to get a separate controller from what I have been reading. That is an insane amount of airflow.
darkphantom is offline
post #6 of 15 Old 04-19-2012, 07:42 PM
A Fluffy Marshmallow
Munkypoo7's Avatar
Quoted: 0 Post(s)
Liked: 334
The fan is powered by a 4-pin molex connector, the 3-pin fan connector is merely a TAC sensor by what the description says, basically an RPM readout (speed sensor).
So in essence, no, this cannot be run off a motherboard, you'll need a 4-pin molex cable.
Unless I've totally missed something.
Foldathon Folder - 2011 Participant  Migration_Sherpa  Foldathon Folder - 2012 Participant  Chimp Challenge 2 x Participant
Munkypoo7 is offline
post #7 of 15 Old 04-19-2012, 07:45 PM
4.0ghz
james_ant's Avatar
Quoted: 0 Post(s)
Liked: 165
Just go to ncix.com and pick up a pair of Scythe Gentle Typhoons, should give you more than enough performance and a lot less noise.
james_ant is offline
post #8 of 15 Old 04-19-2012, 09:31 PM - Thread Starter
technofied's Avatar
Quoted: 0 Post(s)
Liked: 10
does anyone recommend different fans all i want is for them to push more air through the radiater, i dont care how loud they will get but want to use them with h80 fan controller
motherboard is m5a97 evo
post #9 of 15 Old 04-19-2012, 09:47 PM - Thread Starter
technofied's Avatar
Quoted: 0 Post(s)
Liked: 10
just saw it said it draws power from the four pin molex connecter. so if it doesn't draw power from the 3pin then it should work perfectly with the h80 fan controller:o
post #10 of 15 Old 04-19-2012, 10:52 PM
PC Gamer
psyclum's Avatar
Quoted: 0 Post(s)
Liked: 424
it draws power from the molex (meaning it'll run 100% all the time) and output the RPM info on the yellow wire you can plug into the mobo for RPM monitoring....
no known mobo header (except for maybe specially built server boards) can handle a delta (especially a 30 watt delta)
to achieve what YOU want it to do, you'd need a rheosmart controller and plug the fans into the controller and the rheosmart controller will take the PWM signal from your mobo and control the fans accordingly.
my personal recommendation is to go to youtube and look up some 240 CFM 120mm fan vid and listen to just how LOUD those fans will be.
here's one
psyclum is offline
