Fan connector issue. - Overclock.net
post #1 of 4 Old 10-13-2012, 12:08 PM - Thread Starter
lyridsreign's Avatar
Quoted: 0 Post(s)
Liked: 0
A few days ago I ordered a fan off Newegg and made sure it was the right one for me. When it came today I noticed that it was a 3 pin connector. Right now I've got a two fan pin connector because my leads were designed that way. Could someone link me to a 2 pin to 3 pin adapter or something along those lines so I can use this fan? Normally this wouldn't be a problem but I can't seem to find any fans that are only two pin connector.
lyridsreign is offline
post #2 of 4 Old 10-13-2012, 01:03 PM
sinnedone's Avatar
Quoted: 0 Post(s)
Liked: 74
If you have a multimeter to double check its pretty simple
If your fan only has 2 leads then one is power and one is ground. On the 3 pin the extra wire is for rpm.
Look for witing diagrams or pinouts and you can probably wire it up correwctly usig the adapter you bought.
sinnedone is offline
post #3 of 4 Old 10-13-2012, 10:20 PM
Quoted: 0 Post(s)
Liked: 155
The fan plugs are a standard.....
Most 2 pin fans come with 3 pin plugs for compatibility so that it can just plug in,,,,and go....
The same is for PWM fans, they can plug into 3 pin fan headers.
What you are better off doing is taking a pic of the 2pin plugged fan you have, and show us the configuration.
smash_mouth01 is offline
post #4 of 4 Old 10-13-2012, 11:23 PM
Case Modder
airdeano's Avatar
Quoted: 0 Post(s)
Liked: 127
2-pin fan pinout generally is like said above.. red is positive and black is ground.
3-pin fan pinout
4-pin fan pinout
airdeano
airdeano is offline
