200 mm Fan Filter question Azza Solano 1000 - Overclock.net
post #1 of 2 Old 03-30-2013, 01:09 PM - Thread Starter
morinr's Avatar
Quoted: 0 Post(s)
Liked: 1
Hey guys, I am looking to make a filter for my Azza Sonalo 200 mm side fan. It states it is 230 mm however many individuals state that its a 200 mm fan and the 230 mm is from fan screw hole to fan screw hole kitty corner.
I was wondering what you guys think of as a good filter? I want to use some type of screen mesh. However I do not know what specific type to use if that matters. As well as how to secure it to the fan/case.
I would like to cut it to fit and have it so I do not need to take computer apart to clean the filter, would like to just be able to dust it off with a swiffer or use a damp towel before I go to bed for the night.
My searches has just found threads with dead pics that do not work. Or panyhose. I want to keep the side of my case clean looking, which is why I want the screen.
Thanks guys
morinr is offline
post #2 of 2 Old 03-31-2013, 04:58 PM - Thread Starter
morinr's Avatar
Quoted: 0 Post(s)
Liked: 1
Anybody have any information?
I can get screen but the gaps seem much larger than the filters I bought for my 140mm fan intakes.
morinr is offline
