C2D E6600 idle running hot?? - Overclock.net
post #1 of 10 Old 12-22-2006, 01:45 PM - Thread Starter
4.0ghz
BloodThirstyEmu's Avatar
Quoted: 0 Post(s)
Liked: 54
I just got my system built last night and when i checked the bios, it was running 47C idle. Then i went into Asus Probe II and it says 38C. Why is my idle so high? Is it supposed to be this high?
EDIT: I made another thread called 6600 idle hot? but i forgot there is an Nvidia Card called the 6600 so i make a new thread.
I am 89% addicted to Counterstrike.
QTF, I'm facing some painful bottlenecks with solitaire. & BTW Minesweeper is unplayable.
BloodThirstyEmu is offline
post #2 of 10 Old 12-22-2006, 01:48 PM
Retired
tubnotub1's Avatar
Quoted: 0 Post(s)
Liked: 293
That would seem normal for me if you were on stock cooling. One thing to remember is the bios temps are actually not idle temps, they are temps at 70-80% load. If I were you I would go download orthos and TaT, run it, and see what your temps level out at. If they are below 60.1 you are within the suggested temps for your chip. You could always try removing the stock TMI on that HSF and replacing it with some AS5. Good luck!
Originally Posted by Fishie36:
"Wow there's a lot of pwnage going on. But I still don't know how to do it."
Originally Posted by TransfuSe:
"I had a wet dream about his rig once. I woke up and I was stuck to my bed."
Originally Posted by Fatal05:
"In 'collage', people tend to use their BIOS."
1 Million+ Folding at Home points
tubnotub1 is offline
post #3 of 10 Old 12-22-2006, 01:50 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 54
Thnx, ill try that. Also, i have AS5 but installing this stock heatsink was a pain. Ive installed other ones b4 but this one is just really hard. How much of a temperature difference will i get out of the AS5?
post #4 of 10 Old 12-22-2006, 01:53 PM
Retired
tubnotub1's Avatar
Quoted: 0 Post(s)
Liked: 293
Usually you will see a 3-5 c drop versus the stock TMI.
post #5 of 10 Old 12-22-2006, 01:55 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 54
Where can i download TAT and orthos?
post #6 of 10 Old 12-22-2006, 03:44 PM
5 gigs of hert
Quoted: 0 Post(s)
Liked: 511
Are you looking for this one?
http://www.techpowerup.com/downloads/385
Those temps look fine to me
I would lap id the heat pipes n aluminum next them are uneven to get the even.
Kopi is offline
post #7 of 10 Old 12-22-2006, 03:46 PM
Folding Fanatic
Quoted: 0 Post(s)
Liked: 270
And here is Intel Thermal Analysis Tool (TAT) Link
Cooling: D-Tek FuZion [Quad - Nozzle] | MCW60 | MCR320 | DDC-1T /w AlphaCool Top
NEvolution is offline
post #8 of 10 Old 12-22-2006, 03:47 PM
Quoted: 0 Post(s)
Liked: 182
Yes the stock HSF is just plain junk, I used it for a month and I had the exact same temps you had, switched to the AC 7 Pro and idled@34, switched to Tuniq Tower and idled@28C.
Overclock.net 10 Year Member
The Viper is offline
post #9 of 10 Old 12-22-2006, 03:47 PM
The Secret Police
Transonic's Avatar
Quoted: 0 Post(s)
Liked: 429
Transonic is offline
post #10 of 10 Old 12-22-2006, 04:06 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 54
The main problem is my cpu is at 70C on load using TAT. That is not right because my friend JetboyF16 has stock and has oced his to 3.0ghz and his load is 59C
