Worse Temps in Better Case - Page 3 - Overclock.net
post #21 of 27 Old 08-21-2013, 11:34 AM - Thread Starter
WuMyster's Avatar
Quoted: 0 Post(s)
Liked: 4
Originally Posted by doyll View Post
Could be almost anything. Maybe when you moved to new case something got changed in fan speeds.
I assume you are putting the side cover on and waiting 10-15minutes before checking idle temps. biggrin.gif
Waiting even longer actually. I run all the fans on 7V though, and with fans or without fans, the temps should still change. Weird that stopping the fans can have no difference to the GPU temps.
WuMyster is offline
post #22 of 27 Old 08-21-2013, 12:13 PM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Guess it means the airflow around GPU is not keeping heated GPU exhaust air from mixing with airflow going to GPU intakes/fans. This is the kind of thing that the remote sensor indoor/outdoor thermometer comes in handy for.
If you leave the side cover off does GPU stay the same too?
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is offline
post #23 of 27 Old 08-21-2013, 12:17 PM - Thread Starter
WuMyster's Avatar
Quoted: 0 Post(s)
Liked: 4
Yep, whatever I do to the case, the GPU temp stays the same. Its as though its locked to a 36C min.
WuMyster is offline
post #24 of 27 Old 08-22-2013, 12:00 AM
PC Gamer
psyclum's Avatar
Quoted: 0 Post(s)
Liked: 424
ok this is going to be a dumb question, did you change your GPU when you did the case swap? and if you did NOT change the GPU, did you run an alternate / more aggressive fan profile in the XPS? if you are giving it all that airflow, it's down to the GPU fan profile that's actually controlling the temp of your GPU at this point. there is no way in hell after all these changes you are getting worse temps.
psyclum is offline
post #25 of 27 Old 08-22-2013, 02:20 AM - Thread Starter
WuMyster's Avatar
Quoted: 0 Post(s)
Liked: 4
Haha, change my GPU? No. And i was running a constant 30% fan speed in that case which I am doing now. Both have my user defined profile enabled.
WuMyster is offline
post #26 of 27 Old 08-22-2013, 02:46 AM - Thread Starter
WuMyster's Avatar
Quoted: 0 Post(s)
Liked: 4
Well, afterburner is now miraculously reporting a 33C temp HOWEVER, there are spots on the graph where it is 0. For a second or even up to a minute. Im thinking something is wrong. Will a loose card result in wrong readings?
WuMyster is offline
post #27 of 27 Old 09-20-2013, 11:51 AM - Thread Starter
WuMyster's Avatar
Quoted: 0 Post(s)
Liked: 4
Well now that summer has gone and its absolutely freezing in my room. The CPU is at 28C idle and the GPU is at 28 - 30C idle.
No OCs running atm since I took them off previously.
WuMyster is offline
