Replacing Fans on HAF X to Blue LED - Overclock.net
post #1 of 3 Old 09-17-2013, 05:08 AM - Thread Starter
Arkheios's Avatar
Quoted: 0 Post(s)
Liked: 6
Send a message via Skype™ to Arkheios
Hi
I'm currently thinking about replacing the 2x 200mm top, 200mm side panel and 230mm front panel fans with blue LED fans instead of the current red ones.
My concern is, will I be able to replace the 230mm front panel fan with a 200mm fan or won't it fit? CoolerMaster does not have a 230mm replacement fan afaik.
This is the fan I want to install on all the mentioned places of my HAF X: http://www.coolermaster-usa.com/product.php?product_id=2946&product_name=MegaFlow%20200%20Blue%20LED%20%28R4-LUS-07AB-GP%29
Let me know what you think!
Thanks a lot in advance!
Regards,
Andreas
♫ A B C, is as easy as 1 2 ... ♫ - Gabe Newell
GPU History (Click to show)
1x ASUS STRIX GTX 1080 Ti, air
1x EVGA GTX 980 Ti ref., custom water
2x EVGA GTX 780 ACX, air
2x EVGA GTX 680 ACX, air
2x EVGA GTX 580 ACX, air
2x Sapphire HD 6950 flashed to HD 6970 /w shader fix, custom water
1x XFX HD 5850, air
1x Nvidia 9800 GT, air
CPU History (Click to show)
Intel 5930K @ 4.5GHz, custom water
Intel 3930K @ 4.6GHz, custom air
Intel 2600K @ 4.3GHz, custom air
AMD Phenom II X4 965 BE @ 4GHz, custom water
Intel Q8400 @ stock, stock air
Arkheios is offline
post #2 of 3 Old 09-17-2013, 09:47 AM - Thread Starter
Arkheios's Avatar
Quoted: 0 Post(s)
Liked: 6
Seems like it is possible.
Source: http://forum.coolermaster.com/viewtopic.php?f=3&t=14329
1x XFX HD 5850, air
Arkheios is offline
post #3 of 3 Old 09-17-2013, 07:53 PM
Intel Overclocker
Lucky 23's Avatar
Quoted: 0 Post(s)
Liked: 85
Yes the megaflows will fit since the mounting holes are the same as the 230mm stock fans.
You will need this fan for the front if you want to use the LED on/off switch at the top of the case
http://www.cmstore-usa.com/haf-x-200mm-blue-led/
Lucky 23 is offline
