Fans Needed: >100 CFM, 30dBA - Page 2 - Overclock.net
post #11 of 13 Old 10-08-2013, 11:09 AM - Thread Starter
s33dless's Avatar
Quoted: 0 Post(s)
Liked: 1
Originally Posted by airisom2 View Post
Oh, I overlooked that you could use a 140mm fan. In that case, there are two good fans. BitFenix Spectre Pro, and the Silverstone FHP141. I own two of the FHP141 fans. Awesome fan, quiet given the amount of air it moves, fan controller integrated on the fan itself, and is nearly silent on the low speed setting. The downside is that it's 38mm thick, and it has 120mm mounting holes. I haven't used the BitFenix fan, but going off the specs, it should suit your needs perfectly. It pumps out around 122CFMs and the loudest it gets is 29.2dB, according to the specs on Newegg. Plus, it has both 120 and 140mm mounting holes.
I also saw the BitFenix--but I'm worried because that exact same model # also shows up on newegg at a much lower flow rate, and the BitFenix site has no 122 CFM model listed frown.gif
s33dless is offline
post #12 of 13 Old 10-08-2013, 11:33 AM
You don't know what you think you're not doing.
airisom2's Avatar
Quoted: 0 Post(s)
Liked: 257
http://www.bitfenix.com/global/en/products/accessories/spectre-pro-pwm/
Click on the specs tab and scroll down to the 140mm section. It's on their site.
EDIT: The one with the lower flow rate is the non-pwm fan.
EDIT 2: PWM Model: BFF-SPRO-P14025WW-RP
Non-PWM Model: BFF-SPRO-14025WW-RP
4930K 4.3GHz 1.3v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + EVGA Hybrid
Wasabi Mango UHD550 | Rosewill Rise | EK Predator 280
Logitech G600 | G Pro | G440 | G13s | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom made headphones | TEAC-UD501+Wyrd+Passive Preamp | Emotiva Mini-X A100
OCZ Vertex 4 256GB | Mediasonic ProBox 8: 7x Seagate 4TB 1x WD 3TB
airisom2 is offline
post #13 of 13 Old 10-08-2013, 01:23 PM - Thread Starter
s33dless's Avatar
Quoted: 0 Post(s)
Liked: 1
AHA! Thanks a billion man, I completely missed that "P" there. I'll see if I can find the black one anywhere, thanks!
s33dless is offline
