PCI Fan controller - Overclock.net
post #1 of 2 Old 10-29-2013, 01:23 AM - Thread Starter
Folding Fanatic
trojan92's Avatar
Quoted: 0 Post(s)
Liked: 100
I have 4 fans (2 Enermax LED + 2 stock Fractal) that I'd like to add to a fan controller but the way I have my tower set up makes it impractical to be able to open the front door of my R4 and adjust fan speeds which is why a traditional 5.25" fan controller won't do. I was wondering if there are any good fan controllers which I can plug into my PCI slots & also be able to add 4+ fans to it in case I add more in the future.
Thanks.
E5400 @ 3.0ghz > Q8300 @ 3.1ghz > 3570K @ 4.5ghz > 4930K @ 4.5ghz
GT 240 > GTX 460 > GTX 570 > GTX 650 > HD 7850 > HD 7970 > XFX HD 7990 > Sapphire R9 290 TRI-X OC x2 > GTX 980 Jetstream
trojan92 is online now
post #2 of 2 Old 10-29-2013, 01:57 AM
4.0 GHz
Agoriaz's Avatar
Quoted: 0 Post(s)
Liked: 69
You can definitely get fan controllers that are mounted in the PCI brackets. They are usually powered by a Molex.
FrozenCPU PCI Slot Controllers I haven't bought anything from them, but it's a good list of some different ones.
My R3 came with a PCI bracket FC, didn't the R4 include one as well? I know it only has capability of handling three fans, but it's a start.
Time is the best teacher, but it kills its students
Agoriaz is offline
