140mm case fans - Overclock.net
post #1 of 4 Old 11-25-2013, 03:46 PM - Thread Starter
News Fiend
DF is BUSY's Avatar
Quoted: 0 Post(s)
Liked: 89
Hey fellas, need some assistance.
in the market for a pair (2x) of case fans to be used horizontally as top exhaust.
entered in my requirements in newegg filters and sorted it out to around 71 choices : clicky here newegg
-140mm
-any bearing but sleeve
-$0-$25 max price but really looking to spend no more than $15 per fan
-30 or less dBA levels
-colored fans and or LED fans have priority over simple black fans BUT it is in no way/shape/form a deal breaker
does anybody have any recommendations from there? I'd like to stick to newegg but I can do amazon (depending if theres tax involved or not)
p.s
do round-framed fans mount the same way as typical square fans? any mounting holes/distances i should look out for?
the rosewill hyperborea seems to have a insane cfm to noise to price ratio ..... any thoughts on this?
DF is BUSY is offline
post #2 of 4 Old 11-25-2013, 04:38 PM
PC Gamer
CptAsian's Avatar
Quoted: 0 Post(s)
Liked: 55
Send a message via Skype™ to CptAsian
I'm happy with this Xigmatek fan in my XB, as it was easy to install, and it looks good. I don't' think I can comment on it's volume, as pretty much everything in the case is louder than it is. I also really like the fact that it comes in many colors and sizes. However, I can't really compare it to anything else, though.
DF is BUSY likes this.
Clubs (Click to show)
Quotes (Click to show)
Straigtened the pins using a sewing needle and magnifying glass and all was well. Apart from two days later the cpu died completely.
I don't think I've ever operated a hoe between my legs before, so yeah, I'd say it does.
CptAsian is online now
post #3 of 4 Old 11-25-2013, 06:42 PM
Overclocker
GridIroN's Avatar
Quoted: 0 Post(s)
Liked: 40
Bitfenix Spectre Pro are the best 140mm I've found.
I don't know if Cougar makes a 140version of their leading fan, but it would be good too.
-= I heart.gif Mechanical Keyboards =-
GridIroN is offline
post #4 of 4 Old 11-25-2013, 08:04 PM
αC
AlphaC's Avatar
Quoted: 0 Post(s)
Liked: 805
Tater Tot thinks Rosewill hyperboreas are ok (http://www.overclock.net/t/1321074/tator-tots-big-quiet-120mm-140mm-fan-round-up). You shouldn't trust manufacturer numbers though.
Round frames should be fine as long as you have enough clearance (just measure your clearances first befween the fans).
If you're into LEDs Cougar is the way to go. They're one of the few I know that use Fluid dynamic bearings inside their LED fans
Aerocool shark is actually an improved rifle bearing , as is Bitfenix spectre pro http://www.hardwaresecrets.com/article/The-Truth-About-Fluid-Dynamic-Bearing-FDB-Fans/1807/2
Phobya G silent 14 may also be worth looking into.
See this:
http://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fwww.gamezoom.net%2Fartikel%2FCougar_CFD140_GREEN_LED_Test_Review_Exklusiv_-28729-0
http://www.back2gaming.com/hardware/cougar-cooling-fan-round-up-vortex-hdb-and-dual-x-140
Validation (Click to show)
4.49GHz @1.272-1.284V , 11hr Prime95
-> original
gimped BCLK (125W TDP limit)
4.6GHz@1.272-1.284V (Overvolt enabled), 14hr Prime95
4.7GHz @1.296-1.32V (Overvolt enabled), 14hr OCCT Linpack (& F19e BIOS , OCCT 11hr)
4.8GHz @1.296V
5.1Ghz @1.404V (130W TDP) .... wish it was stable
Sandy Bridge Binning guide @ HWBot
AMD Ryzen 7 1700X @ 3.925GHz 1.35V dynamic voltage ... 1hr AIDA64 (8hr AVX Prime95 with -50MHz)
W.I.P R7 1700X @ 4.040GHz (Fixed voltage is bugged , this booted at 1.39V , testing in Windows 10 PE so no GPU driver)
40.75 multi @ 1.39V
41 multi, booted @ ~ 1.41V
Recommended GPU Projects: Einstein@Home , Milkyway@Home (Tahiti , Cayman , Cypress Radeons) (AMD moreso)
Other notable GPU projects: Asteroids@Home (nvidia), GPUGrid (nvidia) , Universe@Home (Tahiti , Cayman , Cypress Radeons with double precision) (AMD)
Project list
AlphaC is offline
