CAMSucks! - An alternative for the CAM software for the NZXT GRID+ - Page 3 - Overclock.net
post #21 of 24 Old 09-29-2016, 11:32 AM
akej74's Avatar
Quoted: 0 Post(s)
Liked: 1
Originally Posted by RoelGoossens View Post
Yes I think I do.
I also noticed that my GRID responses with 0x20 to the init command.
I'm a noob when it comes to Python but I think I'm gonna try and implement support for the v1.
Sounds great, you can use my "grid-simulator" (also on GitHub) to get "Grid Control" running and then modify the simulator to simulate a Grid V1 unit. Should be reasonable straight forward to modify "Grid Control" to support the Grid V1 unit, e.g. use just one of the control settings in "Fan setup" for setting the fan curve for all fans.
Besides this, there may be changes on in the communication protocol, but I tried to keep my code well documented so I hope you can follow along how I have designed it :-)
akej74 is offline
post #22 of 24 Old 09-29-2016, 11:37 AM
akej74's Avatar
Quoted: 0 Post(s)
Liked: 1
Talking about Python, I very much recommend the PyCharm IDE, free "Community" edition available here.
akej74 is offline
post #23 of 24 Old 09-29-2016, 12:25 PM - Thread Starter
RoelGoossens's Avatar
Quoted: 0 Post(s)
Liked: 1
I was just about to ask for a recommendation. Thanks!!
RoelGoossens is offline
post #24 of 24 Old 09-29-2016, 08:05 PM
Overclocker
jura11's Avatar
Quoted: 0 Post(s)
Liked: 97
Hi guys
Did you check tis SW its SIV and looks like its supports NZXT GRID+ V2
Hope this helps
Thanks,Jura
jura11 is online now
