Oiling Gentle Typhoon, should I do it or no? - Page 2 - Overclock.net
post #11 of 21 Old 07-16-2016, 09:31 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Originally Posted by Darknessrise13 View Post
Even through the CClip?
Zep 45 is a pentetrant oil with teflon added. I have often 'fixed' noisy and seized fan and similar motors by just a small amount put on clips / seals, running for awhile and giving them a little more. I have some of the liquid in a little 'pin oiler' something like these. They are quite small .. and hold about ½ fl. oz. (17cc) when full. wink.gif
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is offline
post #12 of 21 Old 07-18-2016, 05:04 PM - Thread Starter
Darknessrise13's Avatar
Quoted: 0 Post(s)
Liked: 2
I have some oil that came with hair clippers, would it be sufficient?
Darknessrise13 is offline
post #13 of 21 Old 07-18-2016, 05:09 PM
JackCY's Avatar
Quoted: 1 Post(s)
Liked: 280
Do you have a silicon oil spray or something? That's what I would use since it doesn't destroy plastic, rubber, etc. unlike WD40 which is kinda aggressive and metal only.
Sure some machine oil should work.
JackCY is offline
post #14 of 21 Old 07-18-2016, 05:42 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 2
Only oil I've got on hand is WD40 and generic oil for hair clippers, mostly made the thread to get an idea of what to use and where to get it. Or if I could even do it, since most ball bearings are sealed.
post #15 of 21 Old 07-18-2016, 11:08 PM
Lady Fitzgerald's Avatar
Quoted: 0 Post(s)
Liked: 514
Assuming you are in the U.S, get this oiler from Amazon. WD-40 is definitely out and I have no idea what kind of oil is used for hair clippers.
Lady Fitzgerald is offline
post #16 of 21 Old 07-19-2016, 02:29 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
WD-40 IS NOT A LUBRICANT!!!
Without knowing what the 'hair clipper oil' is I would guess it is a light machine oil and will work fine.
https://www.amazon.com/Break-Free-CLP-PS-Precision-Shooter/dp/B0050GWAVG/ref=sr_1_2?s=hunting-fishing&ie=UTF8&qid=1468914688&sr=1-2&keywords=oil+pen
https://www.amazon.com/Hoppes-Lubricating-14-9-Precision-Bottle/dp/B0013R67A6/ref=sr_1_1?ie=UTF8&qid=1468914870&sr=8-1&keywords=needle+oiler
doyll is offline
post #17 of 21 Old 07-19-2016, 06:00 AM
Quoted: 0 Post(s)
Liked: 514
Breakfree is an excellent product as is Triflow. Both are primarily for freeing up frozen parts but do leave a decent lubricating film. The problem with both products you linked is they are part of Amazon's Add On program; the OP would have to purchase an additional $25 of other merchandise to be able to buy the two you linked (I wish Amazon would give people the option to pay a bit more for an Add On product instead of forcing them to spend money on additional products they don't need, not to mention I thought Prime was supposed to cover faster shipping on all products).
While I'm not personally familiar with the product I linked, it received excellent reviews and is a synthetic lube. Synthetic lubes normally do not thicken over time, allowing them to last longer, and tend to be "slicker". It's also more affordable since it doesn't require an additional purchase to be allowed to buy it.
post #18 of 21 Old 07-19-2016, 06:45 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
I guess I was just a little distracted by all this 'use WD-40' garbage and trying to find a lower cost alternative.
Synthetic lubes are usually very good. Should work fine.
doyll is offline
post #19 of 21 Old 07-19-2016, 08:35 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 2
Thanks for all your help, I need some stuff from amazon anyways so I'll pick up the hoppes oil and we'll see how it goes. Now to figure out how to remove the paint from the fans... White and red is not easy to match.
post #20 of 21 Old 07-19-2016, 08:40 AM
axipher's Avatar
Quoted: 2 Post(s)
Liked: 268
I use something similar to Starret Tool and Instrument Oil using a needle oil bottle, links below to similar items that I've used:
https://www.amazon.ca/Starrett-1620-Tool-Instrument-Oil/dp/B000KUA2FI
https://www.amazon.ca/SODIAL-Needle-Nozzle-Plastic-Machine/dp/B00IIDYBZ6/ref=sr_1_sc_1?s=hi&ie=UTF8&qid=1468939172&sr=1-1-spell&keywords=neddle+oil+bottle
Spoiler!
axipher is offline
