Corsair ML120 fans - Page 4 - Overclock.net
post #31 of 259 Old 07-26-2016, 02:24 PM
SwagHype's Avatar
Quoted: 0 Post(s)
Liked: 0
Do you thing these rubbers change anything ?
When you look on Pro, its has better finish for me.
BASIC
PRO
SwagHype is offline
post #32 of 259 Old 07-26-2016, 02:54 PM
Dschijn's Avatar
Quoted: 0 Post(s)
Liked: 13
Since the electronics inside are the same, they should sounds very similar. The rubber pads shouldn't change that much at low rpm
Dschijn is offline
post #33 of 259 Old 07-27-2016, 12:01 AM
WaterCooler
Stalefish's Avatar
Quoted: 0 Post(s)
Liked: 2
Originally Posted by Dschijn View Post
Did you also have the NF-F12? Industrial or classic?
I switched from EK -> NF-F12 industrial -> NF-F12 classic and am still not 100% pleased. The fans are in push/pull on a 360 EK Predator and 800rpm is the max. rpm I am comfortable with to achieve a silent system.
So your honest opinion is that they are very quiet and perform well on a radiator? biggrin.gif
The classic ones. I didnt get the industrial since i would never run them at full speed.
I have come to the conclusion that it is the different fan motor noises that bothers me, not the sound of air going through radiators or dustfilters.
The NF-F12 are great fans but they do still sound more then the ML120 in my opinion. The difference is that i can run the ML120 in 1100 rpm and they sound less then the SP120 in 800rpm.
The 3 SP120 is the loudest thing in my PC now due to the buzzing noise from the motor.
If i run them in the full 2400 rpm they sound less then 1850 vardar.
Now of course, i might have been lucky, the next batch of fans might have som problems. Im not in any way a corsair fanboy, these fans are the only thing i have from corsair.
Like the EK Vardar, many people report no problem with those fans but some people do, like me. 4 out of 6 EK vardar 1850rpm that i got had the motor noise issue.
So to answer your question, yes, i think these are the best fans i have had for a long time.
Quiet, no motor noise fans that i have the option to ramp up to get over 4 mmh20 trough my PE360 radiator. And my temps when im gaming went down about 5c delta
Stalefish is offline
post #34 of 259 Old 07-27-2016, 01:22 AM
Dschijn's Avatar
Quoted: 0 Post(s)
Liked: 13
Dschijn is offline
post #35 of 259 Old 07-27-2016, 01:31 AM
Fan Man
Smanci's Avatar
Quoted: 0 Post(s)
Liked: 76
No. They'll be very much useless especially if you attach the fan using normal screws. Always use silicon/rubber screws.
Smanci is offline
post #36 of 259 Old 07-27-2016, 01:58 AM
SwagHype's Avatar
Quoted: 0 Post(s)
Liked: 0
SwagHype is offline
post #37 of 259 Old 07-27-2016, 02:08 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Warning: Spoiler! (Click to show)
BASIC
PRO
Like Smanci said, use the rubber / silicone mounting thingies. thumb.gif
To isolate fan vibration for case requires a vibration mount with vibration dampening on all sides of mounting. The screw makes contact with case around it's diameter and on outside. The only side 'dampened' is between fan and case. This means vibration is transmitted through screw to sides of case hole and case to head of screw .. making the rubber mount on fan worthless.
And old way of vibration dampening was to use a rubber grommet in an oversized cas4e hole. Fractal Design uses this concept for their HDD mounting. Just be careful to not tighter mounting screw too tight or they don't work. wink.gif
One is shinier than the other but I don't think that makes it a 'better finish'.
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is offline
post #38 of 259 Old 07-27-2016, 02:13 AM
Klocek001's Avatar
Location: between the Carpathian Mountains and the Baltic Sea.
Quoted: 0 Post(s)
Liked: 236
don't they come with the fan ?
I mean a single ML120 is three times what a basic Gelid fan costs and that comes with rubber screws
Klocek001 is offline
post #39 of 259 Old 07-27-2016, 02:50 AM
SwagHype's Avatar
Quoted: 0 Post(s)
Liked: 0
I dont know yet, because fans didnt come. On official website is only information "Fan mounting screws" so we dont know what type of screws we get.
SwagHype is offline
post #40 of 259 Old 07-27-2016, 02:59 AM
WaterCooler
Stalefish's Avatar
Quoted: 0 Post(s)
Liked: 2
Its 4 regular black screws for the fan and 2 small zip ties that comes with the ml120 pro
