What's wrong with my PC cooling and how to get maximum performance? - Overclock.net
post #1 of 38 Old 07-29-2016, 06:48 AM - Thread Starter
kariolmax's Avatar
Quoted: 0 Post(s)
Liked: 0
Hello,
at the beginning I want to thank you for this forum and big community. I'm glad I can be there!
My computer was bought in September 2014. Specs: I5-4690k, Gtx 970 Strix, CM G550m, MSI Gaming 3, 2x Crucial Bastilx 8gb 1600mhz 1.5v. Case - SilentiumPC Gladius X60, CPU Cooler SilentiumPC Fortis 3. In case I've got mounted 7 fans (can't fit more beacuse of the window kit). And they are: 3x stock case fan 120mm (included), 2x BeQuiet Pure Wings 2 120mm and 2x BeQuiet Pure Wings 2 140mm. They are mounted like on the picture below - drive cases has been removed. Yellow is 140mm Pure Wings 2, Blue are stock fans from the case and Green are 120mm Pure Wings 2 Thermal Paste's name is Pactum 02 from the box. All fans connected to case's fan controller - while browsing the internet all set on min, while gaming on max. I've overclocked my I5-4690k to 4.5ghz on 1.285v in offset mode, graphics clock +185mhz in afterburner, memory +470. Voltage and fans profiles stood on auto. ASIC 66.6%.. It's stable overclock at all but temps are not funny - in intel extreme tuning utility processor hit 80C, in normal gaming graphics hits 70-74C - the highest fan speed was 55%.
What should I do to decrease them ? Should I try overclocking more? I want to get maximum performance from this PC.
Thank you a lot!
kariolmax is offline
post #2 of 38 Old 07-29-2016, 07:34 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Those temps at 55% fan speed are good.
You might find "Ways to Better Cooling" link in my sig of interest. 1st post is index, click on topic to see it. I suggest starting with 5th topic.
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is offline
post #3 of 38 Old 07-29-2016, 07:53 AM - Thread Starter
kariolmax's Avatar
Quoted: 0 Post(s)
Liked: 0
Thank you for info smile.gif will read later. I was suprised beacuse some people wrote that they have 61C on that GPU in example GTA V on max. For me it's impossible.
edit: Still know the same - that amount of fans doesnt matter, I know that, but I cant be sure that I did well in my PC. ;(
post #4 of 38 Old 07-29-2016, 08:06 AM
Radnad's Avatar
Quoted: 0 Post(s)
Liked: 178
Can you throw up an actual pic of your rig so we can see it? There is a lot of questions that could answer to better help you.
Radnad is offline
post #5 of 38 Old 07-29-2016, 08:17 AM - Thread Starter
kariolmax's Avatar
Quoted: 0 Post(s)
Liked: 0
Specification:
OS: Windows 10
CPU - i5-4690k 4.5ghz 1.285v.
GPU Asus Strix GTX 970
MOBO MSI Gaming 3 z97
Ram 2x Crucial Bastilx cl9 1600mhz
PSU: Coolermaster G550m
Drives: Samsung SSD 840
WD Blue 1tb
Case SilentiumPC Gladius x60
CPU Cooler SilentiumPC Fortis 3 with incluted Pactum 02 paste.
Here are the photos inside: http://imgur.com/a/dEZMn
post #6 of 38 Old 07-29-2016, 08:28 AM
Amiga 500
TUFinside's Avatar
Quoted: 1 Post(s)
Liked: 53
No way you can remove the entire SSD/HDD tray ?
TUFinside is offline
post #7 of 38 Old 07-29-2016, 08:31 AM - Thread Starter
kariolmax's Avatar
Quoted: 0 Post(s)
Liked: 0
There's no way to remove - it's pillar supporting the top of the case.
post #8 of 38 Old 07-29-2016, 08:36 AM
Amiga 500
TUFinside's Avatar
Quoted: 1 Post(s)
Liked: 53
Yes, that's what i thought, what a poor design. Your setup looks fine, apart from re-seating the CPU heatsink (and adding a second fan) and tinker with fan speeds in order to achieve positive pressure (more air in than out), i don't see what you can do. Maybe replacing that case ?
post #9 of 38 Old 07-29-2016, 08:41 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Originally Posted by kariolmax View Post
Specification:
OS: Windows 10
WD Blue 1tb
Bottom fan is only able to draw a fraction of what it should "Ways to Better Cooling" post #15
Fan in case on HDD cage is airblow, not flow. (5th post)
Top fan closest to front of case is pulling hot air up from GPU (5th post)
doyll is offline
post #10 of 38 Old 07-29-2016, 08:42 AM - Thread Starter
kariolmax's Avatar
Quoted: 0 Post(s)
Liked: 0
Hmm, I really like that case beacuse of fan controllers and design, if there's better proposition under 70$, tell me - but I must like new case's design tongue.gif What do you mean about re seating heatsink? It's screwed as hard as it's possible without damaging anything. I can't add second fan - DAC jack's ports interrupts for 0.5cm.... What should I do with fan speeds? I think if the case has to be changed I can afford to buy fan controller. Now I have just settings low and high..
