Cpu Air Cooler help - Overclock.net
post #1 of 5 Old 01-26-2017, 05:56 PM - Thread Starter
333mhz
AquarianLogic's Avatar
Quoted: 0 Post(s)
Liked: 0
Any ideas for a LGA 1151 CPU fan cooler thats on paror even as good as liquid cooling? I know theyre both different just need some ideas.
AquarianLogic is offline
post #2 of 5 Old 01-26-2017, 06:01 PM
Quoted: 0 Post(s)
Liked: 233
Any dual tower and a lot of monoliths will outperform a CLC at similar noise levels. Just get whatever one looks best to you (Cryorig R1, NH-D15S, Dark Rock Pro, etc).
I am a Marxist. Not the Sanders/Sweden/state bureacracy kind, but the workers' democratic control over the means of production kind.
I often use the debates I get into on these forums to demonstrate logical fallacies to to my students and debate teams I coach. Beware - your arguments are under scrutiny of adolescents and teenagers!
claes is offline
post #3 of 5 Old 01-27-2017, 03:53 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
At same noise level almost any half decent air cooler is as good CLC at cooling .. and way more dependable. Air coolers last forever .. at least as long as we will live. Only thing to go bad is fan, which is easy low cost replacement and system will still run without fan or with any fan you might have until replacement arrives. With a CLC if the pump fails .. and that is what happens 99.9% of the time .. there is no cooling until cooler is replace. None at all.
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is offline
post #4 of 5 Old 01-27-2017, 08:35 AM
Fan Man
AyyMD's Avatar
Quoted: 0 Post(s)
Liked: 12
Some of my favorites are the Thermalright Macho Rev.B/X2, Reeven Okeanos (with this, hopefully noise and yellow aren't a problem), Phanteks PH-TC14PE, Scythe FUMA, Thermalright Silver Arrow lineup, and the snexy CRYORIG R1 Ultimate.
AyyMD is offline
post #5 of 5 Old 01-27-2017, 08:43 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
I won't even suggest coolers until we know what your case, motherboard and RAM are. They all play a major role in what size and shape cooler will fit.
doyll is offline
