Looking for very quiet cooler for Ryzen 1700 that will fit on my Asus Prime mAtx board. - Overclock.net
post #1 of 12 Old 12-14-2017, 08:28 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 35
Ok. I've picked the case fans now so I've edited that part out of this post.
All I need now is a good cooler for my Ryzen 1700. Thing is, I'm using an Asus PRIME B350M-E mAtx motherboard, and the ram slots are pretty close to the cpu socket. The wraith Spire cooler I have on there is apparently 103mm wide, and it's pretty close to the ram. The side of the fan casing on it is actually touching the side of the ram. So, I need something that stays narrow enough until it clears the height of the ram. The gpu isn't that far away either. I'd say it's maybe a couple cm below the Wraith Spire fan. The cpu cooler can also be no more than 170mm in height to fit in my case. Anyone know any good coolers that will fit this board? Thanks!
Nevermind. I noticed that Noctua have a motherboard compatability sheet for their coolers so I should be ok now smile.gif
ET900 is offline
post #2 of 12 Old 12-14-2017, 08:40 PM
kd5151's Avatar
Quoted: 6 Post(s)
Liked: 132
kd5151 is offline
post #3 of 12 Old 12-15-2017, 05:33 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
My favorite fans for case, cooler and radiator are Thermalright TY-14x series fans. The TY-147A and TY-147A SQ look good move plenty of air against resistance and are very quiet.
The best and quietest cooler is Le Grand Macho RT .. and it uses a TY-147B fan .. basically same fan as TY-147A.
post-flame-small.gifPhanteks Owners Club post-flame-small.gifpost-flame-small.gifWays to Better Cooling post-flame-small.gif
post-flame-small.gif1. Controling PWM Case Fans post-flame-small.gif2. Optimizing Case Cooling post-flame-small.gif3. Cooler Size Comparison & Cooling Comparison
=i7 980 @ 3.55GHz =PH-TC14PE w/2x TY-143 fans =Crucial Ballistix 3x4GB =GA-X58A-UD5 =ASUS GTX580 DirectCU II =Enermax Modu84+ =Define R2 w/3x TY-140 case intake fans; all PWM controlled by CPU fan socket
Phanteks Enthoo Primo MoBo Rampage III Extreme CPU i7 980xCooler R1 Ultimate w/ TY-147A fans RAM Dominator GT 6x2GB GPU ENGTX580 DCUII PSU Corsair TX850 Case [/COLOR]Phanteks Enthoo PrimoBase custom caster base
=i7 980X @ 4.0GHz =R1 Ultimate w/2x TY-143 fans =Dominator GT 6x2GB =Rampage III Extreme =ASUS GTX580 DirectCU II =TX850 =Enthoo Primo w/ custom castor base
doyll is offline
post #4 of 12 Old 12-15-2017, 12:34 PM
Apple Enthusiast
Quoted: 0 Post(s)
Liked: 0
I picked up three of those NF-P14s Redux fans from Amazon. I wish I could find the TY-147ASQ here in the US but have had no luck to date.
jd63636 is offline
post #5 of 12 Old 12-15-2017, 01:27 PM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Rumors are that Nan's Gaming Gear will have TY-147A SQ by the end of the month. We can only hope rumor is true.
doyll is offline
post #6 of 12 Old 12-17-2017, 04:09 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 35
Thankyou guys. I will be looking to buy some soon so I'll check all of these out smile.gif
ET900 is offline
post #7 of 12 Old 12-17-2017, 05:04 PM
Apple Enthusiast
Quoted: 0 Post(s)
Liked: 0
ive personally not had much success with PWM fans for cases. You can only really set them to ramp up and down with CPU temperature, which (for me at least), causes issues when my GPU is under heavy load and my CPU is hardly doing anything. My GPU gets starved of air because the fans wont ramp up.
I recently bought a fan controller, the aquaero 6, that will allow me to control my fans based on whichever component is hotter so i shouldn't run into this issue anymore. If it doesn't work out (i should have no problems), oh well, i have fun tinkering with my PC anyway haha. Plus i have an awesome tool if i ever wanted to try watercooling at some point... which i have no current desire to do.
AshBorer is offline
post #8 of 12 Old 12-18-2017, 04:02 AM
Commodore 64
doyll's Avatar
Quoted: 0 Post(s)
Liked: 1629
Depends on what motherboard and GPU you have. New motherboard often have PWM control on more than CPU socket.
New Enthoo Luxe comes with a PWM controlled variable voltage fan hub for 3-pin fans
Aquaero 6 is king of controllers. Nothing else even comes close .. except aquaero 5 .tongue.gif
doyll is offline
post #9 of 12 Old 12-18-2017, 07:14 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 35
I'm not sure if I have the option to use the gpu as a source for fan speeds, but I can make my own fan profiles so maybe I can figure out something nice. I guess I'll deal with that when I get to it! No space for a fan controller in my case though. Slowly starting to regret doing an mAtx build. I guess I had to try it at least once though haha tongue.gif
ET900 is offline
post #10 of 12 Old 12-18-2017, 07:25 AM
kd5151's Avatar
Quoted: 6 Post(s)
Liked: 132
Arctic F14/F12 Value pack. 5 fans per pack and comes to like $4-5 a fan. Sucks if you only need one or two fans.
kd5151 is offline
