What are the quietest 80mm fans? - Overclock.net
post #1 of 8 Old 03-09-2008, 05:27 PM - Thread Starter
Pwnererer
Boris4ka's Avatar
Quoted: 0 Post(s)
Liked: 211
Title says it all. Well almost. They need to push some air, but not be louder than around 16 dba. And my fan controller isn't making my current fans as quiet as I'd like; in fact they're the loudest in my system. Any price range. LED's are a plus.
Boris4ka is offline
post #2 of 8 Old 03-09-2008, 05:29 PM
Quoted: 0 Post(s)
Liked: 116
16dba is really quiet. A 80mm fan can will need to spin at high RPMs move a lot of air, and I don't think it'll be able to stay under 16dba.
igob8a is offline
post #3 of 8 Old 03-09-2008, 05:33 PM - Thread Starter
Pwnererer
Boris4ka's Avatar
Quoted: 0 Post(s)
Liked: 211
It doesn't need to move a lot of air, just some so you can feel it a little if you put your hand over it.
Boris4ka is offline
post #4 of 8 Old 03-09-2008, 05:34 PM
4.0ghz
IIowa's Avatar
Quoted: 0 Post(s)
Liked: 53
Silenx fans are good, but expensive. 80mm are really loud for good air flow
Boris4ka likes this.
IIowa is offline
post #5 of 8 Old 03-09-2008, 05:40 PM - Thread Starter
Pwnererer
Boris4ka's Avatar
Quoted: 0 Post(s)
Liked: 211
It's a space where nothing bigger than an 80mm will fit. Maybe a 90mm will fit, but I don't think those are quieter?
Boris4ka is offline
post #6 of 8 Old 03-10-2008, 09:25 PM - Thread Starter
Pwnererer
Boris4ka's Avatar
Quoted: 0 Post(s)
Liked: 211
bump, anyone else?
Boris4ka is offline
post #7 of 8 Old 03-11-2008, 01:25 PM
News Fiend
RayvinAzn's Avatar
Quoted: 0 Post(s)
Liked: 187
Noctua has some excellent 80mm fans but they're rather pricey (although exceptionally quiet), and Enermax has some magnetic-barometric 80mm fans that should be really quiet as well. I've only seen the 120mm Enermax fans in action though, not the 80mm ones so I'm not speaking from experience there. Arctic Cooling also has some FDB 80mm fans out, those might be worth checking out.
Dusted.
RayvinAzn is offline
post #8 of 8 Old 03-11-2008, 07:50 PM
1.7ghz
Quoted: 0 Post(s)
Liked: 23
http://www.svc.com/silent-fan80.html
Scroll down to the very bottem the last 8 (cept the absolute last 2) are Silenx. They are all uber quiet and push air
Carlin is offline
