Arctic cooling freezer 7 pro temps ? - Page 2 - Overclock.net
post #11 of 24 Old 03-10-2008, 04:50 PM
333mhz
Wireless's Avatar
Quoted: 0 Post(s)
Liked: 2
._.
I tend to use speedfan as it's accurate for me, at least?
Idk if it's my mobo or what, but it's always spot on.
Same with Intel TAT.
Originally Posted by OmegaNemesis28
We used to have an infection of "flying ants" (yes, they flew) and were the most ANNOYING ASS things I think Ive ever encountered other then moths.
Exterminator had to come 3-4 times before we finally got rid of them. Or did we? O.o
Wireless is offline
post #12 of 24 Old 03-10-2008, 07:27 PM
Overclocker
pvp309rcp's Avatar
Quoted: 0 Post(s)
Liked: 158
I was running 30-35C idle on my 630i but after upgrading to a 780i and a second 8800gt, I started getting 43-47C idle . Everything is running really hot, especially my ocz powerstream 520w. To find out what was wrong, I took out my second 8800gt. Temps went down to 38-41C. I'm getting a thermaltake toughpower 750w hoping it will bring those temps down. Good luck to me . Btw I actually reached 70-75C when running prime95 for about 4-5 hours . At least I had no errors so my overclock is running stable. No fire or smoke...yet.
Anyway...who wants some mini pizza bagels fresh off my processor .
wave2.gif The OCN Anime/Manga Club wave2.gif
wink.gif Hentai is just anime... wink.gifbiggrin.gif ...with adult content. biggrin.gifsmile.gif Nothing more. Nothing Less. smile.gifmad.gif Screw the hate. mad.gif
Chimp Challenge Participant
pvp309rcp is offline
post #13 of 24 Old 03-11-2008, 06:37 PM
333mhz
stansphat's Avatar
Quoted: 0 Post(s)
Liked: 3
i get 25oC idle. loads never been over 35oC on my q6600. my cpu's cooler than my case, probly cos of the suction cuased by the two extractor fans on the back of my case going at 5000rpm. no fan controler as of yet, but big headache
stansphat is offline
post #14 of 24 Old 03-12-2008, 03:15 AM
4.0ghz
jinja_ninja's Avatar
Quoted: 0 Post(s)
Liked: 131
Try overclocking your quad and you will see your temps go up!
jinja_ninja is offline
post #15 of 24 Old 03-12-2008, 10:54 AM
333mhz
stansphat's Avatar
Quoted: 0 Post(s)
Liked: 3
no doubt about that. im gona take mine up to 2.8ghz. thats it. cos i know it will start to get hot once i start changing vcore. this cpu cooler isnt advised if your doing 3.2ghz +. it will do everything below fine.
i fitted a northern proper north bridge cooler and it took my cpu down 4oC. so on some boards that helps.
lets face it this coolers better than the stock one
post #16 of 24 Old 03-12-2008, 11:50 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 1
I reseated the heatsink and pow Im at 38 C load
Fait is offline
post #17 of 24 Old 03-13-2008, 04:39 PM
2.4ghz
packardhell1's Avatar
Quoted: 0 Post(s)
Liked: 21
I just put 4 92mm Vantec Tornadoes in my case (including one to replace the stock AF7 fan). My temps went from 33C idle to 23C!!! I can finally start overclocking. BTW - the 23 is with a Sunbeam Rheostat fan controller. It was hitting 20-21 on full blast, but I couldn't take the noise Which reminds me, I need to change the name of my rig....
Windows 7Fan Club
Edit: I should note that S&M does not seem to work correctly with Vista.
packardhell1 is offline
post #18 of 24 Old 03-13-2008, 04:45 PM
4.0ghz
Nick226's Avatar
Quoted: 0 Post(s)
Liked: 53
Payton12345 what is your core doing at 1.3vcore, im running 3GHz at 1.28v and its a b3. Bring those volts down or increase speed man
Nick226 is offline
post #19 of 24 Old 03-14-2008, 12:53 PM
333mhz
Quoted: 0 Post(s)
Liked: 4
Mid 50s fully loaded running 1.48v @ 3.0GHz
Demvang is offline
post #20 of 24 Old 03-25-2008, 06:09 AM
1.3ghz
YahonMaizosz's Avatar
Quoted: 0 Post(s)
Liked: 46
Hi guys,
I have AF 7 Pro and it is able to bring my Q6600 to 3.6Ghz (1.46v) without breaking any sweat. However, my question is, under LOAD (1.41v) my temps are 69,69,65,65, why is it that there is a 4C difference between these 2 cores??? Is it too much?? Is something wrong with my heatsink??
YahonMaizosz is offline
