Quick easy question about FM121 - Overclock.net
post #1 of 9 Old 03-19-2008, 12:24 PM - Thread Starter
4.0ghz
RPIJG's Avatar
Quoted: 0 Post(s)
Liked: 150
I see a 4 pin molex and a 3 pin motherboard (with one wire), is the motherboard one needed? Is that just for speed control? I want to use these without the need for the icky speed controller, if I just plug in the 4 pin molex, do I get max speed?
Air Cooled Rampage Formula Results
"And Shepherds we shall be for thee, my Lord, for thee. Power hath descended forth from Thy hand Our feet may swiftly carry out Thy commands. So we shall flow a river forth to Thee And teeming with souls shall it ever be. In Nomeni Patri et Filii Spiritus Sancti."
RPIJG is offline
post #2 of 9 Old 03-19-2008, 12:27 PM
↓ dn ʎɐʍ sıɥʇ ↓
coffeejunky's Avatar
Quoted: 0 Post(s)
Liked: 776
Yup. The molex will give you full (noisy) speed. The 3 pin is just a motherboard header for MONITORING fan speed, only way to adjust fan speed is to use the 'icky' controller.
RPIJG likes this.
bulb.gifCan I Overclock My Brain?... All I Gotta Do Is Increase Its Stock Voltage bulb.gif
ATi Clubs and Essential Threads - ATi Aftermarket Cooling Database - ATi Overclocking Guide - ATi Driver Guide
coffeejunky is offline
post #3 of 9 Old 03-19-2008, 12:29 PM - Thread Starter
4.0ghz
RPIJG's Avatar
Quoted: 0 Post(s)
Liked: 150
How loud are we talking here, I mean it 39.5db which isn't all that terrible realistically.
RPIJG is offline
post #4 of 9 Old 03-19-2008, 12:31 PM
↓ dn ʎɐʍ sıɥʇ ↓
Quoted: 0 Post(s)
Liked: 776
No, not loud for the amount of air it shifts. 'Tis a good fan. I'm just noise paranoid .
post #5 of 9 Old 03-19-2008, 12:32 PM - Thread Starter
4.0ghz
RPIJG's Avatar
Quoted: 0 Post(s)
Liked: 150
I'm thinking I should just go with the FM123 since it can be plugged right into the mobo headers.
RPIJG is offline
post #6 of 9 Old 03-19-2008, 12:35 PM - Thread Starter
4.0ghz
RPIJG's Avatar
Quoted: 0 Post(s)
Liked: 150
maybe I should just go with some scythe's they are cheaper.
RPIJG is offline
post #7 of 9 Old 03-19-2008, 12:36 PM
Still Standing
Quoted: 0 Post(s)
Liked: 2560
If you are wanting to use the 3-pin header, the fan can be modded to eliminate that clunky molex connector.
At max rpm the FM121 is a pretty loud fan, but as already stated, for the amount of cfm you get it is good.
... I love the FM121 fans... just wish they came in black. (only FN121 is black - afaik).
Scythe fans are also very good....
RPIJG likes this.
Custom Case building, dream and build
Custom Cases: Obsidian Silence, Silentium, Halcyon, Anvil, Indigo
Case Mods: Liquid Chameleon, LC-Lan Box
"Semper Fidelis"
Syrillian is offline
post #8 of 9 Old 03-19-2008, 12:45 PM - Thread Starter
4.0ghz
RPIJG's Avatar
Quoted: 0 Post(s)
Liked: 150
I went with the Scythe Kaze-Jyuni, they were about $5-7 cheaper than the Silverstone for what looks on paper at least to be similar performance.
RPIJG is offline
post #9 of 9 Old 03-19-2008, 12:52 PM
4387 point(s) total
Quoted: 0 Post(s)
Liked: 4426
Silverstone FN121 = Good.
All other Silverstone 120mm fans = Bad.
As for the wires, the Intel CPU fan header is PWM. There is a power, ground, sensor, and control wire. With a standard 3-pin plug, you can only monitor the fan speed.
Adjustable 3-pin fan headers use the voltage to control fan speeds. PWM use the control wire to rapidly pulse the power.
To answer most of your questions: (1) a fridge cannot cool a PC (2) 64-bit OS for over 3.4GB (3) If a PCIe card fits, it should work (4) Resolution, not screen size (5) Report, not respond to Spam (6) Single-Rail/Non-Modular PSUs are not always better than Multi-Rail/Modular (7) Sequential does not matter as much as random for OS drives (8) Requirements come before hardware for servers
DuckieHo is offline
