Cpu Cooler - Overclock.net
post #1 of 9 Old 04-11-2008, 02:42 AM - Thread Starter
733mhz
futa_demon's Avatar
Quoted: 0 Post(s)
Liked: 1
I quickly need to find a new cooler. It is for socket 775. I am looking for one like this http://www.pccasegear.com/index.php?...oducts_id=2634 that blows the air out the back of the case. What is the best one of these?
Any help would be much appreciated.
futa_demon is offline
post #2 of 9 Old 04-11-2008, 02:52 AM
4.0ghz
5CheeseLasagna's Avatar
Quoted: 0 Post(s)
Liked: 110
Well, I'll recommend the Tuniq Tower since I own it. It's $49.99 + $7.59 shipping on NewEgg.
http://www.newegg.com/Product/Produc...82E16835154001
In the picture, the fan is the black part (and it is removable), and with the way it's facing, the air blows out the left side. So, if you turn the whole thing around, then you can say it's blowing out the right side.
But anyway, this is considered to be one of the best coolers out there. The other one is the Thermalright Ultra Extreme 120, or "TRUE". It doesn't come with a fan, but it's said to be better than the TT when you have a 120mm fan blowing on it.
Here's a link to the manufacturer's product page:
http://www.thermalright.com/new_a_pa...ler_u120ex.htm
Of course, you can also search for it on something such as Google Shopping:
http://www.google.com/prdhp?hl=en&tab=wf
If you're looking for the best bang for your buck, I'd say the Tuniq Tower is it.
5CheeseLasagna is offline
post #3 of 9 Old 04-11-2008, 02:53 AM
Linux Lobbyist
Quoted: 0 Post(s)
Liked: 81
or you can get a cheaper arctic cooler 7 i hear those are pretty good
What if i was gay???
DjQurt is offline
post #4 of 9 Old 04-11-2008, 03:16 AM - Thread Starter
733mhz
futa_demon's Avatar
Quoted: 0 Post(s)
Liked: 1
What are the height of these coolers. My case is only 18cm wide and has maybe 15cm after you take into account the motherboard and motherboard tray. I am worries they might not fit.
post #5 of 9 Old 04-11-2008, 03:22 AM
Linux Lobbyist
Quoted: 0 Post(s)
Liked: 81
everyone worries about that with the tuniq
*in girl voice* OMG its so big i dont think something that large with fit in my cramped little case! (/girlvoice)
thats when you just grab a hold slide some thermal lube on and shove it in to the tiny crevice and enjoy!
DjQurt is offline
post #6 of 9 Old 04-11-2008, 03:31 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 110
The Tuniq Tower is 15.3cm (153mm) tall. Which case do you have?
post #7 of 9 Old 04-11-2008, 04:13 AM - Thread Starter
733mhz
futa_demon's Avatar
Quoted: 0 Post(s)
Liked: 1
Just some no name case which I have had for a long time.
post #8 of 9 Old 04-11-2008, 04:20 AM
mcogan10's Avatar
Quoted: 0 Post(s)
Liked: 221
ive heard good things about the ninja...my AF7 does a dandy job though for $20.
AI am 75% addicted to Counterstrike. What about you?
Windows 7Fan Club
mcogan10 is offline
post #9 of 9 Old 04-11-2008, 05:26 AM
4.0ghz
linskingdom's Avatar
Quoted: 0 Post(s)
Liked: 3468
It seems that the Thermalright Ultra 120 eXtreme cooler costs extra $5 than the Scythe Ninja Plus over there. If this is the case, I would go for Thermalright Ultra 120 eXtreme cooler.
linskingdom is offline
