Would this hold back air flow? - Overclock.net
post #1 of 4 Old 12-13-2005, 06:36 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 22
Send a message via AIM to X3Nh4nC3D Send a message via MSN to X3Nh4nC3D
http://www.xoxide.com/fanfilter2.html
Im thinking of putting 2 of those on my transformer's side fans, and maybe one on the front 120MM.
Will those hold back air flow?
X3Nh4nC3D is offline
post #2 of 4 Old 12-13-2005, 06:54 PM
bobcool's Avatar
Quoted: 0 Post(s)
Liked: 57
very small dif
bobcool is offline
post #3 of 4 Old 12-13-2005, 06:56 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 132
It does to a point,generally though they try to maintain a balance of flow vs. filter properties.
This looks like a pretty tight mesh,but since it uses tight mesh+thin wire,it maintains a balance.
For a more precise answer,email xoxide about the airflow with these specific filters.
TylerBello is offline
post #4 of 4 Old 12-13-2005, 06:58 PM
Ada///M
adas's Avatar
Quoted: 0 Post(s)
Liked: 595
Send a message via AIM to adas Send a message via MSN to adas
Yes, it does, but only I'd say 1-2cfm...but deifnatly worth it because most of the dust will stay out of your case
adas is offline
