Coolermaster Vortex TX better than Big Typhoon?? - Overclock.net
post #1 of 11 Old 12-14-2005, 11:19 AM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 15
People on here have told me that the Big Typhoon is THE BEST air cooler available. But according to tomshardware, the Titan Vanessa is the best.
Which is better?
EDIT: Mistyped the title. Sry.
gabe1231 is offline
post #2 of 11 Old 12-14-2005, 11:24 AM
Overclocker
accskyman's Avatar
Quoted: 0 Post(s)
Liked: 196
Theres a ton of speculation about what cooler is better. The problem is you can't really compare them as nothing is the same, they could use too much or too little thermal grease, they could use a crap cfm fan etc. It comes down to the fan, thermal grease and a bit of luck. I'd personally go with the typhoon and get atleast 80cfm fan.
BTW the lower the numbers the better, so actually the Vortex is crap.
Chimp Challenge Participant  Overclock.net 10 Year Member
accskyman is online now
post #3 of 11 Old 12-14-2005, 11:31 AM
733mhz
Quoted: 0 Post(s)
Liked: 0
big typhoon would be better than vortex..i trust toms hardware reviews just to be in the safe side i would suggest going with the big typhoon over the vortex..i mean the vortex had the worst review out of the 10 coolers..i dont see the reason why the vortex should be consider to be bought.
night_kidd is offline
post #4 of 11 Old 12-14-2005, 11:35 AM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 15
i explained in my post that i mistyped the title but the post is correct, i meant to refer to the Titan Vanessa.
gabe1231 is offline
post #5 of 11 Old 12-14-2005, 11:38 AM
Overclocker
accskyman's Avatar
Quoted: 0 Post(s)
Liked: 196
I'd go with the Typhoon over any of them, They most likely didn't use a nice fan on it, probably just the one they got with it. Although if you do buy the Titan and a high cfm fan for it, it could be better than a typhoon. (I can't seem to find specs about the fan that comes with it)
post #6 of 11 Old 12-14-2005, 11:40 AM
733mhz
Quoted: 0 Post(s)
Liked: 0
hah!!!! i was having a hard time deciding which of the 2 to go with actually thermaltake has gotten a good reputation so i would say the big typhoon is a good cooler too although i saw 1 bad review from it from somewhere which triggered me to switch to titan vanessa l type..this fan is good man very quiet and cool..im in the middle of overclocking right now and i got my clawwhammer from 2.4 to 2.7 and this cooler has kept my cpu at 35 on idle..so i would say this cooler is doing pretty good so far
post #7 of 11 Old 12-14-2005, 11:42 AM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 15
where'd you get that from night kidd? I looked around on the internet and couldn't find it for sale anywhere?
gabe1231 is offline
post #8 of 11 Old 12-14-2005, 11:44 AM
Overclocker
accskyman's Avatar
Quoted: 0 Post(s)
Liked: 196
Theres a bunch of places froogle.com listed. They seem to be all around 47$.
post #9 of 11 Old 12-14-2005, 11:46 AM
733mhz
Quoted: 0 Post(s)
Liked: 0
i got it on ebay
here is the link
http://cgi.ebay.com/Titan-Vanessa-L-...QQcmdZViewItem
post #10 of 11 Old 12-14-2005, 11:56 AM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 15
will this fan work on the big typhoon?
http://xoxide.com/120mm-nidec-fan.html
gabe1231 is offline
