Fan Fake, Or Real Deal? - Overclock.net
post #1 of 18 Old 12-04-2009, 09:56 AM - Thread Starter
the_geek's Avatar
Quoted: 0 Post(s)
Liked: 10
http://www.newegg.com/Product/Produc...82E16835103062
Comes in red and green, available from tigerdirect also.
Question: They're rated for 90cfm @ 19DBa on every site I checked. Can anyone confirm the validity of this?
Thanks,
the_geek
"I think I've been playing LOTRO to much...I just killed a mosquitoe and I saw a "Devastated" in my mind...... XD" --Nickster777
Laptop: P-6860FX 17"|1.8 GHz|4g RAM|
320Gb HDD|8800M GTS 512 GPU OC'd
the_geek is offline
post #2 of 18 Old 12-04-2009, 09:59 AM
WaterCooler
Quoted: 0 Post(s)
Liked: 190
It most certainly will not. Try silentpc for more informed reviews of case fans.
http://www.overclock.net/air-cooling...le-fans-3.html
Smykster is offline
post #3 of 18 Old 12-04-2009, 09:59 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 145
They're legit. IIRC, they're replacement fans for HAF 922/932 intakes. If you're interested, they're fine.
Xfire: grmnasasin0227
Steam: PWNY
I fold for a cause.
grmnasasin0227 is offline
post #4 of 18 Old 12-04-2009, 09:59 AM
☰ Syrillian
Quoted: 0 Post(s)
Liked: 537
Thanks,
the_geek
Improbable. The test that manufacturers do to come up with these numbers is a complete mystery. If they do have any significant airflow while being very quiet they will have zero static pressure.
RonindeBeatrice is offline
post #5 of 18 Old 12-04-2009, 10:00 AM
2.4ghz
Quoted: 0 Post(s)
Liked: 30
Yes they are very quiet I have the red version
Jura55ic is offline
post #6 of 18 Old 12-04-2009, 10:01 AM
TwoCables's Avatar
Quoted: 13 Post(s)
Liked: 6212
Thanks,
the_geek
They are indeed quiet, but the 19dB is unfortunately the rating for its slowest speed. Worse yet is that the box these come in (and also now Cooler Master's website) say it's rated at 69.69 CFM. This rating of 69.69 CFM seems much more reasonable for how powerful these feel.
I have the blue LED version of this fan, and it's a really quiet fan at 2000 CFM. It's much quieter than I anticipated. If you don't mind the space-age looking black-light type of appearance these have in the dark (they don't really emit much light, but you can certainly see the light), then I absolutely recommend this fan both as a case fan and moreso as a CPU heatsink fan.
These also have a static pressure (or air pressure) rating of 3.04 mmH2O. It certainly feels like this is accurate (judging how the air pressure felt right in front of the fan).
 Semi-Classic Firefox Add-ons Manager (CSS script)
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
TwoCables is online now
post #7 of 18 Old 12-04-2009, 10:02 AM
One block at a time
Quoted: 0 Post(s)
Liked: 319
here's the deal with these fans, they do pump out 90cfm but with not the best static pressure, the 19db rating isn't from when it's at max rpm though, its probably more around 1600 or 1500 rpm opposed to 2000rpm, still at 2000rpm they aren't that loud, i'd say under 309db at 2000rpm
good fans though, I have like 4-5 I believe
also the package of my red led still says 90cfm
____________________________
.:|Official|Volt|Mod|Squad|Member|:.
tha d0ctor is offline
post #8 of 18 Old 12-04-2009, 10:02 AM
4.0ghz
da tick 07's Avatar
Quoted: 0 Post(s)
Liked: 117
blahh they arent 90cfm. they do push plenty of air tho. GREAT fan for the price
da tick 07 is offline
post #9 of 18 Old 12-04-2009, 10:03 AM
733mhz
clowdermilk89's Avatar
Quoted: 0 Post(s)
Liked: 16
They are amazing fans I replaced all three of my 120mm intake fans with the green ones and they are very quite and lowered temps by about 3C
clowdermilk89 is offline
post #10 of 18 Old 12-04-2009, 10:03 AM
Gone
Skylit's Avatar
Quoted: 0 Post(s)
Liked: 570
Yep, they're 69 CFM. A Cooler Master representative said they crank all the way up to 90 CFM though with PWM... I think he's lying though TBH.
Skylit is offline
