Cooler Master Hyper 212 Plus/EVO Club - Page 352 - Overclock.net
post #3511 of 6667 Old 01-20-2012, 08:14 PM
PC Gamer
Maynard46's Avatar
Quoted: 0 Post(s)
Liked: 1
the fan that comes with the hyper 212....its got a 4 pin connector for the cpu fan controller on the mobo
So i have a 2nd one of these fans...can that 4 pin connector plug into a 3 pin slot on the mobo without any troubles?
Also...the 2nd fan should be used as an exhaust pointing towards the rear...correct?
Maynard46 is offline
post #3512 of 6667 Old 01-20-2012, 10:08 PM - Thread Starter
PC Gamer
Quoted: 0 Post(s)
Liked: 238
Originally Posted by laser23 View Post
Could you please make it to include to hyper 212 evo owners like me, cos there is no evo club, and both heatsinks are so similar theres no point having 2 clubs.
added
chinesethunda is offline
post #3513 of 6667 Old 01-21-2012, 05:41 AM
WaterCooler
Matt-Matt's Avatar
Quoted: 0 Post(s)
Liked: 225
If you look at the 4 pin fan, you'll see on one side it has some notches, basically this is if you want to use a 3 pin.. 3 of them will line up and it will click in (sort of).
This will run at full speed, unless you can do that in your bios? (I know it can be done, but I've never tried it)
Also that's correct, you want one to push (the one that came with it) and the second one to pull air out towards the back, that is unless the cooler is mounted sideways (like mine), and it's facing up. Then you'll want to have them both pull air up! thumb.gif
Matt-Matt is offline
post #3514 of 6667 Old 01-21-2012, 05:48 PM
4.0 GHz
Whitehair's Avatar
Quoted: 0 Post(s)
Liked: 0
Whitehair is offline
post #3515 of 6667 Old 01-21-2012, 09:39 PM
laser23's Avatar
Quoted: 0 Post(s)
Liked: 2
laser23 is offline
post #3516 of 6667 Old 01-21-2012, 09:50 PM
WaterCooler
Matt-Matt's Avatar
Quoted: 0 Post(s)
Liked: 225
Originally Posted by Whitehair View Post
Can i join
700
Can I join the club?
315
post #3517 of 6667 Old 01-21-2012, 10:31 PM
Stanfiem's Avatar
Quoted: 0 Post(s)
Liked: 3
Here you go Im in what is this about the sig though I want to display the rep loud and proud!
700
Cooler Master Hyper 212+ Club
i5 2500k @ 4.3 GHZ
MSI GTX 970 4g gaming 1546 / 7600
Kingston 8GB 1600
Gigabyte Z68XP-UD4
Seagate Barracuda 1
antec 520
Cooler Master 212+
Rosewill RANGER
Stanfiem is offline
post #3518 of 6667 Old 01-22-2012, 02:25 AM
WaterCooler
Matt-Matt's Avatar
Quoted: 0 Post(s)
Liked: 225
700
[center][url="http://www.overclock.net/t/632591/cooler-master-hyper-212-plus-club"][B][COLOR="Blue"]Cooler Master Hyper 212+ Club[/COLOR][/B][/url][/center]
post #3519 of 6667 Old 01-22-2012, 02:44 AM
Overclocker in Training
Caustic Fox's Avatar
Quoted: 0 Post(s)
Liked: 0
I picked up the CM 212+ very recently. Umm... was it just me or was clamping down the mounting bracket into the screw holes somewhat difficult for anyone else? Also the cooler still kinda moves (Though still very tightly fastened to the board.)
Caustic Fox is offline
post #3520 of 6667 Old 01-22-2012, 03:55 AM
WaterCooler
Matt-Matt's Avatar
Quoted: 0 Post(s)
Liked: 225
That sounds about right, it barely moves though. Only if you push it with your hand?
Mine still does that, but leave it in the desired position (straight) and the thermal paste will set, therefore it will stick a bit. I'm fairly sure that's what happened with mine and why when i removed the cooler there was a massive patch that was still wet..
