Cooler Master Hyper 212 Plus/EVO Club - Page 501 - Overclock.net
post #5001 of 6667 Old 10-30-2012, 05:56 AM
(V);,,;(V) Why not Zoidberg?
Conspiracy's Avatar
Quoted: 0 Post(s)
Liked: 276
its easy. just look up vids before you install
Bronica ETRSi, 75/2.8, 135/4
Minolta XD11, 28/2.8, 50/1.4
Canon 5DmkIII, 7D, 17-40/4L, 100/2.8 macro, 135/2L, 70-200/4L IS, 1.4X mkIII
YN-560II, YN-560III
flickr
2 Million+ Folding at Home points
Conspiracy is offline
post #5002 of 6667 Old 10-30-2012, 09:15 AM
Overclocker in Training
./Cy4n1d3\.'s Avatar
Quoted: 0 Post(s)
Liked: 64
Originally Posted by Conspiracy View Post
Anyone ever think, that since the two together don't really improve temps by too much, to lower the fan speed on a dual fan setup to match a single fan setup? If 1 fan gets you good performance, and 2 fans give slightly more good, make two fans do the work of one to lower the load on each, thus fan speed, and thus noise.
Originally Posted by Layo View Post
Hey, picking up my 212+EVO in few hours, I never installed fan, could anyone shortly tell me how to do it on 1155 mobo? Ill look up vids after.
Eh... Honestly, if it is the same way as a Hyper 212+, then it isnt' the easiest installation. Not extremely difficult, but I would say that you will need to look up a video rather than the instructions (I didn't think the instructins were that good.). If you ahve any questions, you can ask us... maybe even video call us so we can give better tips.
Just remember... Don't lift your heatsink after you have put it on teh thermal paste, as it will create air bubbles. Once it lands, don't pick it up.
./Cy4n1d3\. is offline
post #5003 of 6667 Old 10-30-2012, 09:42 AM
First Time Build
Khaled G's Avatar
Quoted: 0 Post(s)
Liked: 18
^ This !
1- You have to correctly position the back plate then screw it tight. (The tricky part, as it's double sided)
2- Apply your TIM using either the grain method or 2 parallel lines. (The grain method worked for me).
3- Decide how you will orient your heatsink (Horizontal or vertical), seat it and screw it tight. (Diagonally, evenly)
4- Connect your fan(s) and you're ready to go.
I have a 1155 mobo, If you need pics just tell me.
Pffffffft (Click to show)
Browsing Russian porn sites....
Woah... They do have those buttons.
5 Million+ Folding at Home points
Khaled G is offline
post #5004 of 6667 Old 10-30-2012, 10:54 AM
Quoted: 0 Post(s)
Liked: 64
Originally Posted by Khaled G View Post
^ This !
Yeah. Good tips.
I had problems when I went to reapply thermal paste. When you install, you put your bracket screws and then you have more screws which screw into the head of the bracket screws. For some reason, I sorta forgot, and i left the mounting screws on the final screws and it made reseating a mess... I finally remembered and fixed my problem, but it botched that thermal paste install and I had to reclean and reapply.
post #5005 of 6667 Old 10-31-2012, 02:21 AM
basedwise's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by edsai View Post
No, the Blade Master 120mm doesn't come with this blackets.
It only comes with 4 screws and the anti-vibration rubber pads.
Thanks! I managed to find the extras so now I can add another fan!
Do you basically just stick the 2 pieces on the new blade master fan just like the one that came with the 212? Also, how do you remove the thermal paste when you want to resea the heatsink? Is there a solution you need to apply to properly remove the old thermal paste?
basedwise is offline
post #5006 of 6667 Old 10-31-2012, 03:17 AM
4.0 GHz
wongwarren's Avatar
Quoted: 0 Post(s)
Liked: 54
To remove old thermal paste just use a few drops of alcohol and toilet paper to wipe it off.
wongwarren is offline
post #5007 of 6667 Old 10-31-2012, 04:02 AM
PC Gamer
xd9denz's Avatar
Quoted: 0 Post(s)
Liked: 31
why you didnt pick two identical Corsair SP fans?
And why AF then SP Corsair FAN combination?
xd9denz is offline
post #5008 of 6667 Old 10-31-2012, 04:53 AM
Graphics Card Aficionado
Layo's Avatar
Quoted: 0 Post(s)
Liked: 11
Picking up my 212+ in around hour then I'm gonna try to install it. Hope I wont break anything and i really hope I can even install it biggrin.gif Not sure where am I gonna point my fan to, either back or top... my GEIL rams are pretty high.
Layo is offline
post #5009 of 6667 Old 10-31-2012, 05:27 AM
First Time Build
Khaled G's Avatar
Quoted: 0 Post(s)
Liked: 18
I'll take and post some pics for the installation to help you out (and everyone else)
Make sure to check back here before you start the installation.
Khaled G is offline
post #5010 of 6667 Old 10-31-2012, 05:57 AM
Layo's Avatar
Quoted: 0 Post(s)
Liked: 11
Thank you. I got the idea, you screw there the backplate (how? biggrin.gif), do some work on cpu side, get the X part trough the heatpipes and mount it there. Should be like this, right?
Layo is offline
