Best TIM btw these choices? - Page 3 - Overclock.net
post #21 of 27 Old 06-09-2010, 08:15 PM
3.5ghz
pieisgood2's Avatar
Quoted: 0 Post(s)
Liked: 46
Originally Posted by boredgunner View Post
I have had the opposite results on 3 different coolers in the same case. The bottom line is that any difference between the two pastes is so small so it really boils down to tube size and price.
To apply the paste on your parts, you must put a rice grain sized drop in the center of the CPU, and put your CPU cooler directly on top of it. Do not spread it, this would cause air bubbles which will reduce heat transfer. Make sure your CPU and CPU cooler look brand new before applying the TIM. Clean it off with high percentage alcohol or ArctiClean. Use cotton swabs and tooth picks for the small gaps in the CPU socket.
acticlean is awesome stuff
paras likes this.
pieisgood2 is offline
post #22 of 27 Old 06-09-2010, 08:18 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 133
i love my AS5, "outdated" or not it usually performs within 1-2*c of any other top paste, and i love the way it spreads and the tube lasts forever
as far as application, a dot the size of a BB or a grain of rice usually works best
paras likes this.
Ice98 is offline
post #23 of 27 Old 06-09-2010, 08:31 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 113
AS5 is probably the best value since a tube does last a long freakin' time. My fave is IC Diamond...which is available worldwide thanks to FrozenCPU.com
paras likes this.
"It's all fun and games until the penguin drops the chainsaw..."
---The Saint Louis Overclockers Club---
Dorkseid is offline
post #24 of 27 Old 06-09-2010, 08:49 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 70
AS5 isnt bad but for the same price you can get MX-2 or OCZ freeze which are better than AS5. Therefore there is no point in getting AS5.
OCZ contains 3g, MX-2 contains 4.0g and AS5 contains 3.5
So you are basically gaining .5g with the MX-2 or losing .5g with OCZ freeze but your temperature will be slightly lower than the AS5. Plus you don't have to wait for them to cure unlike AS5.
So therefore it is illogical to buy AS5 anymore...
paras likes this.
Lossless > foobar2K > Wasapi > Musiland 02 DAC > [Dayton SUB80 > KRK RP5 G2] / [ATH-M50]
ThumperSD is offline
post #25 of 27 Old 06-10-2010, 05:38 AM - Thread Starter
paras's Avatar
Quoted: 0 Post(s)
Liked: 19
have ordered MX 2
paras is offline
post #26 of 27 Old 06-10-2010, 03:00 PM
3.5ghz
pieisgood2's Avatar
Quoted: 0 Post(s)
Liked: 46
Originally Posted by paras View Post
have ordered MX 2
good choice, you will love it. should see temp drops off the bat with no cure time.
btw has anyone tried coollaboratory's liquid metal pro or ultra. it seems pretty good and i have been thinking about trying it. just need some confirmation on it.
post #27 of 27 Old 06-10-2010, 04:22 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 113
The PITA factor involved in removing it has been off-putting thus far, but I've been tempted...
Dorkseid is offline
