RAM getting HOT! - Page 2 - Overclock.net
post #11 of 16 Old 06-09-2010, 07:46 AM
Audiophile
Quoted: 0 Post(s)
Liked: 107
Fantasysage is offline
post #12 of 16 Old 06-09-2010, 09:32 AM - Thread Starter
333mhz
newcalc's Avatar
Quoted: 0 Post(s)
Liked: 1
i got a 120mm fan now,
the dimms are touchable now.
i think i'm gonna get me some of those passive coolers
additionally.
thanks for the clues, guys
newcalc is offline
post #13 of 16 Old 06-09-2010, 09:47 AM
Overclocker
Redwoodz's Avatar
Quoted: 0 Post(s)
Liked: 571
Just for kicks,what case are you using? The memory cooler will work fine,but I'm a little curious what your case cooling is,usually there is no need for dedicated mem cooler unless your doing some real heavy overclocking.Reason I ask is some better case cooling might do you better for your whole system,not just your memory,especially if you plan on overclocking your cpu and onboard graphics.
eek.gifAMD Athlon II 450 @4.74GHz http://valid.canardpc.com/show_oc.php?id=2204588
AMD MaxxMemm Rankings
960T @ 4.6GHz http://valid.canardpc.com/show_oc.php?id=2171450
X6 running 4.125GHz 24/7 @1.47v
Chimp Challenge 2 x Participant
Redwoodz is offline
post #14 of 16 Old 06-09-2010, 10:50 AM
Intel Overclocker
Lost-boi's Avatar
Quoted: 0 Post(s)
Liked: 23
Guess im lucky that ive never had a hot stick of ram other than my old DDR OCZ platinums. My DDR3 stuff is never hot at all.
Lost-boi is offline
post #15 of 16 Old 06-11-2010, 04:26 AM - Thread Starter
333mhz
newcalc's Avatar
Quoted: 0 Post(s)
Liked: 1
currently my computer lies on my desk, as i'm reseating the cpu and stuff,
so i have better access.
i directed a 120mm fan towards the dimms, so that it pushes through between the dimms,
result: better touchable, but still very hot, when running prime for like 30min.
and this is more active cooling, than a case airflow.
so the rams definately suck.
newcalc is offline
post #16 of 16 Old 06-11-2010, 04:31 AM
Old School
Quoted: 0 Post(s)
Liked: 1522
It's normal for memory to run hot, and they can easily take 90c. If the memory voltage is at 1.6v you don't even need additional cooling over the memory.
Acoma_Andy is offline
