Thermaltake Polo 735 Any good? - Overclock.net
post #1 of 9 Old 03-22-2006, 10:13 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
hey guys,
Im looking to buythis
are they any good because my cpu is hitting around 50 55C at idle with amb. at around 35C most of the time. case is thermaltake soprano with the extra two 120mm fans and 80mmfan, I have artic silver 5, have recently reapplied, very slight change in temp. any help would be greatly appreaciated as Im going to buy this cooler in about 15 mins.
(have posted thread about this problem before)
thanks in advance.
by the way, its not oc`d anymore, stock 2.66G Socket478
Azrael_AU is offline
post #2 of 9 Old 03-22-2006, 10:21 PM
4.0ghz
uberjon's Avatar
Quoted: 0 Post(s)
Liked: 69
i like it. the only problem i see is that its going to be loud!
but i like it.
Holds true to today, I'm 21 and still a punk kid at heart XD (but Im packing broadband now, woo hoo dL`in pr0nz up to 49877489187327 times faster)
uberjon is offline
post #3 of 9 Old 03-22-2006, 10:27 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
I dont really care if its loud soo long as my temps drop to under 50C Im happy
post #4 of 9 Old 03-22-2006, 10:30 PM
Audiophile/Car lover
pbasil1's Avatar
Quoted: 0 Post(s)
Liked: 460
well i doubt it will be much better than a stock cooler... how much do you have to buy a new HSF? for around $50 you can get THE BEST air cooler out, and its the TT big typhoon, for a little less lke $30-37 you can get the zalman 7700cu... or a scythe ninja(but it needs a seperate 120mm fan)
so IMHO i dont thing its worth it... you will most likely buy and just be dissapointed!
Like cars? Carforum!
How to choose the right fan
what is " folding " ???
When you take an old graphics card and effectively 'fold' it in half, in order to remove the chip.This process takes alot of power.
Foldathon Folder - 2011 Participant  Chimp Challenge 2 x Participant  10 Million+ Folding at Home points  Foldathon Folder - 2013 Participant
pbasil1 is offline
post #5 of 9 Old 03-22-2006, 10:41 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
I dont know where I can get the big typhoon in australia, not many places around brisbane would have them, I have about 50 aussie dollars to play with for this project.
would watercooling be a better option?($170)
post #6 of 9 Old 03-23-2006, 01:26 AM
333mhz
Quoted: 0 Post(s)
Liked: 2
water cooling is always good
neties is offline
post #7 of 9 Old 03-24-2006, 10:24 PM
Fan Man
Quoted: 0 Post(s)
Liked: 67
I run an AMD XP2600+. I just bought the Thermaltake Polo 735 Rev.2 last week after putting up with warmer than wanted temps since buying it. Using the stock HSF @ stock speed (1912Mhz) idle was 60C, load up to 67C. After putting the 735 on (with AS5 paste), at stock idle was 48C load 51C. Clocking it up to 2127Mhz idle is 49-50C and load is 53-54C.
Noise - under full load it sounds like there is a vacuum in the next room; although that was when I had it set on auto and it would spin up to 5300rpm. I've plugged in the manual dial now and found the right compromise between cool vs db's.
I got it from umart for $45, best CHEAP investment I've made for my pc!
Ask me no questions and I'll tell you no lies....
Other Systems:HTPC ; Shiggles
7 Million+ Folding at Home points
to_the_zenith is offline
post #8 of 9 Old 03-24-2006, 10:27 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 324
I would recommend it for a decent "budget" cooler. Also get the "ducting mod" for it and it will give you another 3-5 degrees.
Stinger Slingers V5
insanity reigns
It's better to reign in hell than serve in heaven.
There is more to life than increasing its speed. - Mahatma Gandhi...guess he's not a member of Overclock.net
1 Million+ Folding at Home points
busa is offline
post #9 of 9 Old 03-25-2006, 06:30 PM
5 gigs of hert
Quoted: 0 Post(s)
Liked: 511
I would recommend the XP-90. Depending on where you buy it could cost you anywhere from (including fan) $40-$55. They cooled my temps by about 10c stock for load and idle. I'm running a 900mhz OC at an idle of 34c. Amazing cooler, absolutely amazing. Kinda left behind by the TT BT craze
I would lap id the heat pipes n aluminum next them are uneven to get the even.
Kopi is offline
