Can too much thermal paste = higher temps? - Page 2 - Overclock.net
post #11 of 17 Old 05-10-2006, 03:09 PM
4.0ghz
xsabrewulf's Avatar
Quoted: 0 Post(s)
Liked: 13
I have to reseat mine
because mine is stock and in BIOS it says its 40 degrees
i just dont know how tight to put the bt, i dont want to break anything but it has to be tight enough to spread the AS5
xsabrewulf is offline
post #12 of 17 Old 05-10-2006, 03:11 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 86
Get it a bit past "Snug" tightness.
24/7 3.36 Overclock
3.43 GHz shot
92% of teens have moved on to rap. If you are part of the 8% who still listen to real music, copy and paste this.
funkycasey is offline
post #13 of 17 Old 05-10-2006, 03:14 PM
4.0ghz
xsabrewulf's Avatar
Quoted: 0 Post(s)
Liked: 13
well its really hard to tell how tight it is.
i have a K8 board and it has the back bracket so i only need 2 screws. and its not easy to tell how tight it is.
post #14 of 17 Old 05-10-2006, 03:39 PM
noxious89123's Avatar
Quoted: 0 Post(s)
Liked: 135
Tighten till your CPU cracks. then you know the limit. Then buy a new CPu and tighten down just before breaking point. Thats how i would do it.... if i was filthy rich..
noxious89123 is offline
post #15 of 17 Old 05-10-2006, 03:50 PM
4.0ghz
jrabb1920's Avatar
Quoted: 0 Post(s)
Liked: 471
It would be better if you take the motherboard out to make sure its installed properly.
jrabb1920 is offline
post #16 of 17 Old 05-10-2006, 05:09 PM
Now Available in Orange
Fishie36's Avatar
Quoted: 0 Post(s)
Liked: 751
Best advice I've seen all day
Fishie36 is offline
post #17 of 17 Old 05-10-2006, 09:19 PM
333mhz
Quoted: 0 Post(s)
Liked: 1
Originally Posted by Sideburns
The cure time for AS5 is not a dramatic drop in temps. Everyone one here makes it sound like it's the be all and end all. If his temps are crap, no amount of "curing" will fix it.
ive gotten huge drops from letting the as5 cure for just a few days. one time i re-sat my heatsink, the temps were around 55C idle, within a few days it went down to about 45C idle. the huge drop may have partly been my fault though, while doing some re-arranging in my case, i remounted the heatsink and found that my previous mounting wasnt that great. most of the as5 was only to one side. ive got everything mounted fine right now though.
kofrad is offline
