Help me choose a graphics card - Page 2 - Overclock.net
post #11 of 17 Old 04-14-2013, 11:52 AM
raghu78's Avatar
Quoted: 0 Post(s)
Liked: 1084
raghu78 is offline
post #12 of 17 Old 04-15-2013, 09:24 AM - Thread Starter
Audiophile
AMD guy's Avatar
Quoted: 0 Post(s)
Liked: 3
Originally Posted by raghu78 View Post
go with a HD 7850 2GB. should be more than enough for 1440 x 900.
http://www.ebuyer.com/390921-sapphire-hd-7850-oc-2gb-dual-dvi-hdmi-displayport-pci-e-graphics-card-11200-14-20g
Kinda expensive for my budget, I think I will get a 7750 since its like half the price.
Also I still don't have a CD drive in my PC, damnit
biggrin.gif i keed
AMD guy is offline
post #13 of 17 Old 04-15-2013, 09:28 AM
333mhz
BackwardPawn's Avatar
Quoted: 0 Post(s)
Liked: 1
If you're sure you're sticking with that res, go with the cheaper card. I just upgraded from a 22" 16:10 to a 27" 1080p and am loving it. If I was paying for the upgrade, I'd have gone 1440p, but I can't really beat free.
If you might upgrade you'll want the better one.
BackwardPawn is offline
post #14 of 17 Old 04-15-2013, 01:28 PM - Thread Starter
Audiophile
AMD guy's Avatar
Quoted: 0 Post(s)
Liked: 3
I wasn't planning to get a better monitor any time soon so I guess I'll just buy the 7750, unless there are any better nvidia alternatives but I don't think so tongue.gif
biggrin.gif i keed
AMD guy is offline
post #15 of 17 Old 04-15-2013, 06:27 PM
Soul Craze's Avatar
Quoted: 0 Post(s)
Liked: 3
I think i can help you with this our setups are quite similar. Here are my system specs:
AMD Phenom II X6 1055T
Gigabyte 990XA
Asus HD 7750 820Mhz
Corsair Vengeance 2X4GB 1600Mhz
Corsair CX430M
Acer X193w 1440x900 resolution
My computer runs all my games fine at medium to high settings (BF3, Skyrim, Simcity, Planetside 2 etc) But one day i wanted to record some gameplay and upload it to youtube just to show other people how surprisingly good the HD 7750 was but once i started recording with fraps skyrim started lagging hard and became unplayable even when i slightly lowered the settings. I tried a different recording program but that didn't change anything.
So in my opinion at least the HD 7750 with likely run all of your games (even most modern games) at a reasonable setting with playable FPS but if you are planning on recording i would personally buy the HD 7850 2GB because it's a smarter investment and is just overall a more powerful and capable card.
Edit: I'm not entirely sure recording was laggy because of my video card, i don't have much experience with recording video.It was probably because i have only one hard drive and the footage was saving to that as i was recording.
Soul Craze is offline
post #16 of 17 Old 04-15-2013, 06:50 PM
AlphaC's Avatar
Quoted: 1 Post(s)
Liked: 805
ASUS GTX 650-E is the only comparable NVIDIA card. The other GTX 650s need a power connector , GT 640 is slower than HD7750.
1GB
http://www.superbiiz.com/detail.php?p=AS-650EGD5
http://www.microcenter.com/product/411367/GTX650-E-1GD5_NVIDIA_GeForce_GTX_650_1024MB_GDDR5_PCIe_30_x16_Video_Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121710
2GB (more for show)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121714
http://www.superbiiz.com/detail.php?p=AS-650E2D5
P.S.
http://www.techpowerup.com/reviews/ASUS/GeForce_GTX_670_Direct_Cu_Mini/26.html
Validation (Click to show)
4.49GHz @1.272-1.284V , 11hr Prime95
-> original
gimped BCLK (125W TDP limit)
4.6GHz@1.272-1.284V (Overvolt enabled), 14hr Prime95
4.7GHz @1.296-1.32V (Overvolt enabled), 14hr OCCT Linpack (& F19e BIOS , OCCT 11hr)
4.8GHz @1.296V
5.1Ghz @1.404V (130W TDP) .... wish it was stable
Sandy Bridge Binning guide @ HWBot
AMD Ryzen 7 1700X @ 3.925GHz 1.35V dynamic voltage ... 1hr AIDA64 (8hr AVX Prime95 with -50MHz)
W.I.P R7 1700X @ 4.040GHz (Fixed voltage is bugged , this booted at 1.39V , testing in Windows 10 PE so no GPU driver)
40.75 multi @ 1.39V
41 multi, booted @ ~ 1.41V
Recommended GPU Projects: Einstein@Home , Milkyway@Home (Tahiti , Cayman , Cypress Radeons) (AMD moreso)
Other notable GPU projects: Asteroids@Home (nvidia), GPUGrid (nvidia) , Universe@Home (Tahiti , Cayman , Cypress Radeons with double precision) (AMD)
Project list
AlphaC is offline
post #17 of 17 Old 04-15-2013, 11:56 PM - Thread Starter
Audiophile
AMD guy's Avatar
Quoted: 0 Post(s)
Liked: 3
Thanks for all of your help, I think it's best if I get a 7850.
Just to be safe
biggrin.gif i keed
AMD guy is offline
