Eyefinity side monitor stretchy - Overclock.net
post #1 of 11 Old 01-16-2011, 11:57 PM - Thread Starter
3.5ghz
DaRookie's Avatar
Quoted: 0 Post(s)
Liked: 57
I've research on this and some people are having the same problem. Crysis, COD, and CSS is stretch out on two side monitor. It's related to FOV (Field of Vision) but where do I adjust this setting? game config or ATI CCC?
DaRookie is offline
post #2 of 11 Old 01-17-2011, 12:02 AM
3.0ghz
Dranx's Avatar
Quoted: 0 Post(s)
Liked: 28
Quick question, are your monitors all straight and flat against the wall like this:
_ _ _
Or are they slightly tilted towards you on the side monitors like this:
_
Of course, not to such an extreme angle like the diagram above, but they should be slightly tilted to your liking to contrast with the stretchiness.
Dranx is offline
post #3 of 11 Old 01-17-2011, 12:05 AM - Thread Starter
3.5ghz
DaRookie's Avatar
Quoted: 0 Post(s)
Liked: 57
I tried both but I decided to tilt it slightly towards me. Like your second diagram but more diagonal.
DaRookie is offline
post #4 of 11 Old 01-17-2011, 12:09 AM
3.0ghz
Dranx's Avatar
Quoted: 0 Post(s)
Liked: 28
And it is still stretchy? Even after you tilted it? Either try tilting it some more or if you absolutely hate it being that way then try google as I have no experience with dual monitors tongue.gif Sorry.
Dranx is offline
post #5 of 11 Old 01-17-2011, 12:14 AM
4.0 GHz
Blue Marker's Avatar
Quoted: 0 Post(s)
Liked: 115
I think the only way to fix it is something called the Widescreen Fixer.
Blue Marker is offline
post #6 of 11 Old 01-17-2011, 12:45 AM - Thread Starter
3.5ghz
DaRookie's Avatar
Quoted: 0 Post(s)
Liked: 57
DaRookie is offline
post #7 of 11 Old 01-17-2011, 12:47 AM
Retired Member
windfire's Avatar
Quoted: 0 Post(s)
Liked: 1352
Originally Posted by DaRookie;12039944
Try to run it in a single monitor setting.
Widescreen Fixer works for some games, not all, unfortunately.
For some games, FOV can be adjusted via a Console Command.
For some, the game's .ini or .cfg file needs to be edited.
And some games need some hacks.
Check out ''Games, Hacks & Tools'' here: http://www.widescreengamingforum.com/wiki/Essential_Games_List
windfire is offline
post #8 of 11 Old 01-17-2011, 12:51 AM
tagurtoast's Avatar
Quoted: 0 Post(s)
Liked: 140
Widescreen fixer DOES Fix MW2 and BLOPS and works very well at it. It is normal for the side monitors to look a bit stretched BUT the centre Monitor should be perfect ( as in the same as if you had one monitor for the centre only)
You don't have a computer. You cannot use the TV.
tagurtoast is offline
post #9 of 11 Old 01-17-2011, 12:55 AM
PC Gamer
Sircles's Avatar
Quoted: 0 Post(s)
Liked: 64
you can change thee FOV in BLOPS in the menu somewhere
Sircles is offline
post #10 of 11 Old 01-17-2011, 12:56 AM
4.0 GHz
Quoted: 0 Post(s)
Liked: 115
What he said. My TF2 works wonderfully at 4800x900 but there is a slight stretch to the sides. This includes L4D. I can barely notice it when I'm playing the game.
