Need help overclocking the Phenom II 940BE - Overclock.net
post #1 of 10 Old 04-17-2012, 11:33 AM - Thread Starter
peste19's Avatar
Quoted: 0 Post(s)
Liked: 1
I currently have my cpu overclocked to 3535Mhz and cant get passed it, i have it with a multiplier of 17.5 and fsb of 202, memory at 1076
voltages are:
CPU - 1.5V
NB VID - 1.17V - Stock
NB = 1.3V - Stock
Any suggestions to help me pull this any further? I see that people can overclock way more and i am struggling to get passed his
thanks in advance
peste19 is offline
post #2 of 10 Old 04-17-2012, 01:37 PM
railfan844's Avatar
Quoted: 0 Post(s)
Liked: 198
You've likely just hit the ceiling of your CPU. More than 1.5v won't increase that by much and will approach the high end of voltages where the lifespan impact and heat output begin to increase exponentially.
If it makes you feel better the most I got out of my x4 Phenom was a stable 3.4 at around the same voltage.
nope.avi
railfan844 is offline
post #3 of 10 Old 04-17-2012, 01:48 PM
Kyronn94's Avatar
Quoted: 0 Post(s)
Liked: 33
Try overclocking the CPU/NB to around 2600-2800MHz, it;s known to benefit Phenom II's quite a lot.
I'm pretty sure you stop seeing any increase in performance after 2800MHz.
Just try and keep your HT link close to 2000MHz.
My 955 'only' gets to 3.6GHz, needs too much voltage to go any higher.
Chimp Challenge Participant  3 Million+ Folding at Home points  Foldathon Folder - 2013 Participant
Kyronn94 is offline
post #4 of 10 Old 04-17-2012, 03:24 PM - Thread Starter
peste19's Avatar
Quoted: 0 Post(s)
Liked: 1
i read some place that increasing the nb vid voltage helps with fsb overclock is that true?
peste19 is offline
post #5 of 10 Old 04-17-2012, 04:05 PM
AMD Overclocker
Speced's Avatar
Quoted: 0 Post(s)
Liked: 41
A little bit, I would just use the multi instead of messing with the board's voltage.
haro
Speced is offline
post #6 of 10 Old 04-17-2012, 04:12 PM - Thread Starter
peste19's Avatar
Quoted: 0 Post(s)
Liked: 1
multi of what? i cant go anymore on the processor, if i put it on 18x, it crashes
peste19 is offline
post #7 of 10 Old 04-17-2012, 04:15 PM
AMD Overclocker
Speced's Avatar
Quoted: 0 Post(s)
Liked: 41
You're running DDR2 right? Drop that to 800. And up the fab a little bit more.
Also C2 chips max out at 3.6 to 3.8 most of the time.
Sent from my iPod touch using Tapatalk
haro
Speced is offline
post #8 of 10 Old 04-17-2012, 09:08 PM - Thread Starter
peste19's Avatar
Quoted: 0 Post(s)
Liked: 1
tried that but if i increase the fsb, the computer wont post
peste19 is offline
post #9 of 10 Old 04-17-2012, 09:26 PM
Overclocker
mongen's Avatar
Quoted: 0 Post(s)
Liked: 22
You're saying it doesn't post on 203? What about if you drop to 17x multi? Can you go up to FSB 205 or 206 stable?
Also, what BSOD do you get past 3535MHz? I am facing a similar problem. FSB203 and 17x multi (3450MHz) is rock solid on this 720BE, but 204 crashes in games and Prime with a memory error 0x50. Doesn't matter if I loosen the timings, or drop the memory to 800 or even 667.
Also, agree on upping the NB. Add a few volts and get it to 2.6 or so - massive performance increase there.
peste19 likes this.
mongen is offline
post #10 of 10 Old 04-18-2012, 07:13 AM - Thread Starter
peste19's Avatar
Quoted: 0 Post(s)
Liked: 1
i can get to 203 but not stable, if i put 204 computer wont even post, i currently have my NB at 2400Mhz tried upping it to 2600mhz with voltage increase but didnt see any performance increase, been using the amd overdrive benchmark to see the computer performance rating.
However will try later to lower the multi to 17x and up the fsb to see if i can get an higher overclock however i have to reach around 208 to achieve a similar overclock to what i have now
peste19 is offline
