Problems of Many Sorts - Overclock.net
post #1 of 5 Old 01-09-2006, 08:11 AM - Thread Starter
Commodore 64
xenocide's Avatar
Quoted: 0 Post(s)
Liked: 0
My exact Specs are listed in my Spec thing.
I am wondering if there's a drawback to having 2GB of RAM, i can't get my OCZ Performance RAM to run at the advertised timings with 2GB in, or for that matter at 200MHz. Is it something to do with my mobo, cpu, or something else? i know it's not the RAM.
Also, i'm having a lot of performance issues, i got a mere ~8200 on 3DMark03 and 4100 on the CPU part of 3DMark05, and 4800 on the Graphical part. Once they came up i started thinking something was wrong, and the 03 Score convinced me something was wrong. It's strange because my friend with the same Mobo, an AMD Athlon 64 3200+, Connect3D x800GTO, and 1GB G.Skill PC3200 is getting better performance than i am. Any help would be appreciated.
xenocide is offline
post #2 of 5 Old 01-09-2006, 12:55 PM
4.0ghz
tytlyf's Avatar
Quoted: 0 Post(s)
Liked: 79
You are running 4 sticks or ram, you have to run 2T. 4 sticks cant run 1T as far as i know. See if this helps your problem. now if you had 2x1G then you would be able to 1T them.
tytlyf is offline
post #3 of 5 Old 01-09-2006, 01:04 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 1203
His motherboard will automatically change to 2T. (DFI does make 1 board that can run 1T with 4 sticks) I'm guessing that your Epox defaults to 333mhz when using 4 Dimms. Look it up on the Epox's website or in your manual.
Comp #2: Intel 2500k, GTX480, MSI P67AGD55, 4gb G Skill, X-Fi XtremeMusic,Logitech Z5500, 24" Gateway LCD, Antec P180,3 striped 36gb Raptors + 1 500gb, Hyper 212+, Corsair 520HX.
Comp #3:Intel 2500k, GTX480, MSI P67AGD55 , 4gb G Skill, Antec 650W, Logitech 560 4.1, 24" Acer LCD, Chenming MidTower, Liteon DVDRW, 74gb Raptor + 500 gb, Hyper 212+, Creative X-Fi XtremeGamer.
Comp #4: Intel 2500k, MSI 6950 2gb, Asus P8P67A, 4gb G. Skill, 22" Acer LCD,Raptor 150, Hyper 212+, Logitech 530, Antec P180, Antec TruePower 650w,Creative X-Fi XtremeMusic,Liteon DVDRW
sccr64472 is offline
post #4 of 5 Old 01-09-2006, 04:43 PM - Thread Starter
Commodore 64
xenocide's Avatar
Quoted: 0 Post(s)
Liked: 0
I know it does, but the problem is i can't get it to change, or else it won't boot, any possible fix? or will i have to run 1GB or 1.5GB of RAM =x
xenocide is offline
post #5 of 5 Old 01-09-2006, 05:28 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 1203
You know it does what? That it won't run 4 DIMMS at 200mhz? If that's the case, there's nothing you can do really. You can try to OC, but there's a reason your motherboard is adjusting the speeds downward. It's just not good at running 4 sticks. My MSI board can run 4 sticks at 200 mhz, but I have no idea about Epox.
Edit: The Epox Ultra can, so yours should also.
http://anandtech.com/mb/showdoc.aspx?i=2465&p=16
