Max voltage for XP 2200+? - Overclock.net
post #1 of 1 Old 03-09-2006, 06:54 PM - Thread Starter
333mhz
the_texan's Avatar
Quoted: 0 Post(s)
Liked: 1
Where would I go to find the max safe voltage for an AMD Athlon XP 2200+ (Thoroughbred) that the nominal voltage is 1.65? Nominal means what it's factory set at right? The reason I'm asking is that I beleived that as long as the CPU didn't exceed about 55C (50 to be safer), then i could keep raising the multi/fsb/voltage. Is this inaccurate? If there is a max voltage not to push past, then I really would like to know so that I don't fry my processor without knowing it. Right now, I'm running it at 2.0, stable at 2.33Ghz (stock 1.83). I might go ahead and back it down some anyways.....paranoia gets the best of me alot, but sometimes it winds up being my best friend.
the_texan is offline
