Low CPU Multipliers BADDD? - Overclock.net
post #1 of 5 Old 04-03-2006, 03:53 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 715
Hi, i was just wondering if you run a 2.0GHz CPU at 200x10 would it run the same as 250x8? Not considering the RAM speed, since they are both are 2.0GHz is there much of a difference between 200x10 and 250x8? thanks
JacKz5o is offline
post #2 of 5 Old 04-03-2006, 04:24 PM
rippon's Avatar
Quoted: 0 Post(s)
Liked: 124
You would get better performance at 250 X 8 because the ram is running faster. But the CPU speed would be the same.
I'll be on my new website: Robotics News
rippon is offline
post #3 of 5 Old 04-03-2006, 04:35 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 715
ya i know the RAM would run faster but would higher FSB/HTT and low multipliers bad for the CPU in any way? performance would be same but would it cause more heat or anything?
JacKz5o is offline
post #4 of 5 Old 04-03-2006, 04:37 PM
Ada///M
adas's Avatar
Quoted: 0 Post(s)
Liked: 595
Even if the ram is at the same speed, I belive the cpu is still faster with a higher bus speed. It does not hurt the cpu in any way to run really high fsb, but it might take a bit extra voltage
JacKz5o likes this.
adas is offline
post #5 of 5 Old 04-03-2006, 07:41 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 715
great, thanks alot guys
JacKz5o is offline
