Help me get above 2.4!!! X2 4400+ - Overclock.net
post #1 of 3 Old 04-05-2006, 11:38 PM - Thread Starter
1.3ghz
tonkoshala's Avatar
Quoted: 0 Post(s)
Liked: 2
Here is where I'm at right now...
Core is at 2453.3
1.35 V
FSB 223 X 11
MEM timings at 2.5 3 3 5 16 16
Any ideas? I'm still pretty new at this...Anything over what my settings atre now with out messing with the voltage (not sure, but heard 1.5 is safe?) and I can't get into windows...
tonkoshala is offline
post #2 of 3 Old 04-05-2006, 11:44 PM
Retired Staff
r3tard's Avatar
Quoted: 0 Post(s)
Liked: 157
Drop your hypertransport to 4 X, hmm.... Try 1.4 volts and try a X10 multiplier with 240 FSB. The ram shouldn't hold you back. Make sure to lock your pci/pci-e frequency at 100.
r3tard is offline
post #3 of 3 Old 04-06-2006, 04:00 AM
Commodore 64
Ladylasha's Avatar
Quoted: 0 Post(s)
Liked: 0
Core is at 2453.3
1.35 V
FSB 223 X 11
You have the same board and cpu as me try this
For my 4400 the setting are as follows
amd x2 4400
Asus a8n32
FSB 260
CPU Multi X10
SB>NB Multi X5
K8>NB X3
SB>NB Linkwidth 16/16
K8>NB Linkwidth 16/16
cpu vcore set at 1.46
the memory i selected limit and picked the 200mhz
Memory timing 3-4-4-8 1T
Field Value
Real Clock 260 MHz (DDR)
Field Value
Effective Clock 520 MHz
Field Value
Bandwidth 8320 MB/s
Vdimm set at 2.75
Out come running 2.6ghz stable over 24h
Good Luck
Ladylasha is offline
