Lapping vs. IHS Removal - Page 3 - Overclock.net
post #21 of 34 Old 11-12-2006, 02:57 PM
..the party can start now
Quoted: 0 Post(s)
Liked: 589
Remove the IHS
pros:
better temps
faster
easier
less likely to bend a pin
cons:
people THINK it's risky (it really isn't as long as it's not epoxied on)
You have to modify the heatsink bracket if it's the stock-style mounting...
There you have it...
Sideburns is offline
post #22 of 34 Old 11-12-2006, 06:25 PM - Thread Starter
4.0ghz
Dock #89's Avatar
Quoted: 0 Post(s)
Liked: 26
Originally Posted by Sideburns View Post
Remove the IHS
pros:
better temps
faster
easier
cons:
Those two cons are probably why I won't do it though.
Originally Posted by Eska
all i see is a stupid chip that i dont have
Dock #89 is offline
post #23 of 34 Old 11-12-2006, 07:06 PM
Freeze It
MADMAX22's Avatar
Quoted: 0 Post(s)
Liked: 582
as long as its not am2 either because those are soldered on, but 939's are usually ok
E6400@3856E4300@4158E6600@4510,Opti148@3102,opti170@2918,UD3P&9550@4692
UD3P&84005304,UD3p&85005567
4 Million+ Folding at Home points
MADMAX22 is offline
post #24 of 34 Old 11-13-2006, 01:18 PM - Thread Starter
4.0ghz
Dock #89's Avatar
Quoted: 0 Post(s)
Liked: 26
I wonder if they plan on doing this to all of their new chips in the future...
Dock #89 is offline
post #25 of 34 Old 11-13-2006, 01:25 PM
Quoted: 0 Post(s)
Liked: 589
people THINK. Key word was think. it's not actually dangerous...all the 939 CPUs are fine.
second point...modifiying the bracket...
If you get an aftermarket cpu fan it's usually a scrwe on type and is not required..
for stock style though...all you do is use sandpaper and sand down the 4 little TINY pegs on the back...it's REALLY REALLY easy.
Trust me. it's not as hard as you think. I thought it would be hard to..then I laughed when I got it finished...
post #26 of 34 Old 11-13-2006, 10:10 PM - Thread Starter
4.0ghz
Dock #89's Avatar
Quoted: 0 Post(s)
Liked: 26
I'm sure it's not hard, and I'm sure I will do it eventually
It's not about the IHS, it's about working with the bracket. I really despise working on it, as I have broke more than one (bad luck?) by simply putting on a new HSF. Stupid clipon stuff... when will they bring out the velcro?
Dock #89 is offline
post #27 of 34 Old 11-13-2006, 10:39 PM
4.0ghz
beret9987's Avatar
Quoted: 0 Post(s)
Liked: 188
Sounds like my CNPS9500 won't crack my die right? I'm really tempted to do this weekend since I'm doing a major overhaul on my system and I might as well get it over with. I got an Manchester X2 3800+ though. Think I can pop the IHS off?
*EDIT* Planning on buying the Swiftech Apex Ultra Water Cooling Kit. will that CPU block crack my die?
I just read the title... Is this thread about trading your GF for a video card? Are you willing to trade her for a 7950GT? smile.gif
ALL men see in only 16 colors, like Windows default settings. Peach, for example, is a fruit, not a color. Pumpkin is also a fruit. We have no idea what mauve is.
beret9987 is offline
post #28 of 34 Old 11-13-2006, 10:47 PM - Thread Starter
4.0ghz
Dock #89's Avatar
Quoted: 0 Post(s)
Liked: 26
You could always try measuring stuff with a ruler I really wouldn't know, but just be careful when you are mounting anything on it, and I believe it would make sense to be level with it: meaning, hold it level while you are mounting it.
Dock #89 is offline
post #29 of 34 Old 11-13-2006, 10:49 PM
Habitual Tinkerer
Quoted: 0 Post(s)
Liked: 1192
No it's easier to mount a WB than a HSF on one..Just be sure to tighten it down evenly and you should be OK....The only bad thing is you really need to use a WB like the Swifty Storm instead of the Apogee...The Storm's inlet is directly over the center of the cpu die, while the Apogee's inlet is on the side....I guess the Apogee would still work but it would not cool as well....The Storm block is also very restrictive and is usually used in a single block system...
***Beware all ye Men born of Woman, beware the Hemogoblins...biggrin.gif...If you argue with a Troll the Troll wins. Do not feed the Trolls.***
***TOS***OCN's Professionalism Initiative*** An Emphasis on Quality of Content***Frozen Path. Sub-Zero Cooling Club***
***E8500 @ 5736 Mhz** E8600 @ 5751Mhz***E8400 @ Dead piece of junkQuote:
Originally Posted by Patch
Makes sense. Trolls have nickel plated red blood cells. Helps their copper based hemogoblin deal with the high aluminium content in their spleens.
ira-k is offline
post #30 of 34 Old 11-13-2006, 10:50 PM
4.0ghz
beret9987's Avatar
Quoted: 0 Post(s)
Liked: 188
It's REALLY tempting since AMD puts that crap thermal grease on the IHS and its probably killing my temps=killing my OC and I REALLY wanna see if I can get 3Ghz out of my chip. Any videos on where I can see this popping off done? Also, how can I tell if its soldered on?
