Lapping vs. IHS Removal - Overclock.net
post #1 of 34 Old 11-10-2006, 04:08 PM - Thread Starter
4.0ghz
Dock #89's Avatar
Quoted: 0 Post(s)
Liked: 26
Title says all, which should I do? (P.S. I plan on doing this to my 3200 Venice and a 3700 SD that I want to get.)
By the way, are they going to solder on all IHS's from now on?
Originally Posted by Eska
all i see is a stupid chip that i dont have
Dock #89 is offline
post #2 of 34 Old 11-10-2006, 04:09 PM
Freeze It
MADMAX22's Avatar
Quoted: 0 Post(s)
Liked: 582
depends on what you wanna do, youll get better temps with ihs removal but its far riskier and youll have to mod your hsf a bit to get it to fit right
they are both pretty easy to do, but if you dont have the cash to replace a broken cpu i would just lap it and call it good
Dock #89 likes this.
E6400@3856E4300@4158E6600@4510,Opti148@3102,opti170@2918,UD3P&9550@4692
UD3P&84005304,UD3p&85005567
4 Million+ Folding at Home points
MADMAX22 is offline
post #3 of 34 Old 11-10-2006, 04:14 PM - Thread Starter
4.0ghz
Dock #89's Avatar
Quoted: 0 Post(s)
Liked: 26
That is what I'm considering, but really, I am wondering if AMD used a different paste/thermal conductor between the core and the IHS, would there be a difference at all?
Dock #89 is offline
post #4 of 34 Old 11-10-2006, 04:15 PM
The CanAsian
UberN00B's Avatar
Quoted: 0 Post(s)
Liked: 344
Why not do both? and no, they havnt changed anything.
On a budget Build? See my FAQ!!
http://www.overclock.net/faqs/36946-...-system-i.html
UPDATED MARCH 5th 07'
NEW! Overclock.net Ping boosted CS:S Server - overclock.nuclearfallout.net:27015
UberN00B is offline
post #5 of 34 Old 11-10-2006, 04:16 PM
4.0ghz
born2killU's Avatar
Quoted: 0 Post(s)
Liked: 166
If you take off the IHS dont replace it with AS5
that is a waste of time
take off the IHS and run it without it
BTW what heatsink do you have
you cant run it with no IHS on the stock heatsink unfortunately
born2killU is offline
post #6 of 34 Old 11-10-2006, 04:17 PM
Quoted: 0 Post(s)
Liked: 185
they just have some generic paste in there...it's white...
dotcomthese is offline
post #7 of 34 Old 11-10-2006, 04:18 PM - Thread Starter
4.0ghz
Dock #89's Avatar
Quoted: 0 Post(s)
Liked: 26
Sorry for the bad wording, I meant, what if they changed the product they use right now with something different (or better.)
I am going to use a Big Typhoon VX (diferent mounting system from the original BT kind of scares me), but I am starting to think I will just lap both the IHS and the BT instead of removing the IHS; for ease of mind really.
Dock #89 is offline
post #8 of 34 Old 11-10-2006, 11:11 PM
4.0ghz
mudd's Avatar
Quoted: 0 Post(s)
Liked: 124
i'm running naked and its dropped my load temps at 3 ghz from 56c to 44c and my big typhoon is lapped and polished.
mudd is offline
post #9 of 34 Old 11-10-2006, 11:18 PM
listen
d3daiM's Avatar
Quoted: 0 Post(s)
Liked: 497
I believe what I will be doing will be the absolute extremest way to keep my temps down, without phase or TECs
I will be watercooling with a swiftech apogee, I will lap the apogee, I will be removing the IHS of my sandy, and I will be using Coolaboratory Liquid Pro thermal compound
d3daiM is offline
post #10 of 34 Old 11-10-2006, 11:19 PM
Multi-Quote King
Quoted: 0 Post(s)
Liked: 845
Removing my IHS raised my temps about 3C, but i think that's because my HS clips on (you can still jiggle it or twist it a little when it's clipped in). I'd say remove the IHS if you have a HS that screws in or solidly clamps onto a bracket.
I lapped my IHS, though, and it gave me good results, about 3C drop. Plus, since i had removed my IHS i got to replace the crap that they had in between for stock (they missed like half of the damn core). The IHS was also very concave, as was the stock HSF (took me about 3 hours to get it flat).
"I just talk the way I see things... If that's offensive to you... I'm sorry; you're a loser." - Michael Savage
"But you would be amazed by how many people think that the only reason to have a computer is to play games, and that playing games is all that anyone with a computer does." - dangerousHobo
The Hundred Gunner is offline
