Entry level gaming APU based system for my friend? - Overclock.net
post #1 of 9 Old 07-25-2013, 01:49 AM - Thread Starter
4.0 GHz
MrSharkington's Avatar
Quoted: 0 Post(s)
Liked: 31
Hi there, my friend wants me to build him a PC for under (or just a little over) 500 bucks, here in Australia the majority of parts are quite overpriced, but this is what I have managed to come up with (note: case was his preference)
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=192944&action=wish_lists
Does anyone have any recommendations, preferably just from this site thanks biggrin.gif
MrSharkington is offline
post #2 of 9 Old 07-25-2013, 02:09 AM
edalbkrad's Avatar
Quoted: 0 Post(s)
Liked: 220
https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=192885&action=wish_lists
Get the matching strike-x psu, its only $3 more
http://www.pccasegear.com/index.php?main_page=product_info&products_id=22536
I can vouch for the psu quality, im using it right now, my friend also has one in his i5 ivy rig.
It should also be a lot stronger than a 430w psu.
I revised the wishlist a bit to save some cash:
I know the asus writer is better quality, but your friend probably wont burn a lot of discs so a cheaper one would be fine. The seagate 500GB is also cheaper than WD which is quite a surprise.
Too bad the gigabyte and msi boards at around $90 dont have vrm heatsinks.
MrSharkington likes this.
edalbkrad is offline
post #3 of 9 Old 07-25-2013, 02:09 AM
akromatic's Avatar
Quoted: 0 Post(s)
Liked: 99
intent of use for the PC?
you really want dual channel(2 sticks) of atlest 1866mhz ram for the APU to shine
and do you really need/want that big of a case/board? maybe a matx would be more suitable
consider
http://www.pccasegear.com/index.php?main_page=product_info&cPath=138_1441&products_id=23204
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_733&products_id=22958
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_733&products_id=5771
akromatic is online now
post #4 of 9 Old 07-25-2013, 02:32 AM - Thread Starter
4.0 GHz
Quoted: 0 Post(s)
Liked: 31
consider
He's using it for gaming and basic web browsing. I might get that Motherboard instead so I can have some money left for more ram, as it is very, VERY overpriced here. And it was his choice on the case, I'll see if he might want something different.
post #5 of 9 Old 07-25-2013, 02:38 AM - Thread Starter
4.0 GHz
Quoted: 0 Post(s)
Liked: 31
or do you think 4gb is fine for entree gaming? he doesnt do video editing or anything so..
post #6 of 9 Old 07-25-2013, 02:45 AM
edalbkrad's Avatar
Quoted: 0 Post(s)
Liked: 220
The ram prices went up recently so 4gb should be fine for now.
He can just add another stick later on if he wants to dual channel.
My ram usage never gets past 3gb when gaming.
The only reason i have 16gb is because I use after effects which eats like 11gb on a project.
post #7 of 9 Old 07-25-2013, 04:42 AM
akromatic's Avatar
Quoted: 0 Post(s)
Liked: 99
4GB is minimal IMO, remember you are going to assign a healthy portion to the iGPU for games, probly 1GB worth
post #8 of 9 Old 07-25-2013, 06:19 AM - Thread Starter
4.0 GHz
Quoted: 0 Post(s)
Liked: 31
Thanks for everyone's input, I'll just leave him with 4gb for, as he is on quite a tight budget.
post #9 of 9 Old 07-25-2013, 09:43 AM
Overclocker in Training
Alanim's Avatar
Quoted: 0 Post(s)
Liked: 120
Make sure you get him dual channel memory, otherwise an APU system will choke up.
4GB "Might" be fine, but APUs do share the main system memory so he'll only have access to 2-3GB of his RAM.
Also those RAM price increases are insane.
Alanim is offline
