Help, PC won't boot - Page 2 - Overclock.net
post #11 of 20 Old 12-24-2006, 04:19 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 157
Here is something that helped me with the exact same problem.
Start off by making sure all your hookups are plugged in
atx+12v+ any other connector
now unplug it from the wall or turn the switch off.
Take all your ram out and put one in the main slot (some it's the 3rd one up)
take your cmos battery out
Hold your power button down for 1min to drain any power left in the board
set it to bios jumper to clear, and wait
after 30min-24hours put your battery back in and move the jumper back into its normal spot
plug in a PS2 keyboard (No a USB one will not work) and hold insert down.
Plug in your PSU
Turn it on and see.
Monkmachine likes this.
PaRaDoX is offline
post #12 of 20 Old 12-24-2006, 04:58 AM - Thread Starter
4.0ghz
Monkmachine's Avatar
Quoted: 0 Post(s)
Liked: 157
Right I've change the mobo and now its sorta working, keep getting blue screen of death evertime I boot into windows, something about irq driver. I think I will be able to get somewhere now!!! I'll post back any updates or if I get stuck with a problem. Thanks Guys!!!
Monkmachine is offline
post #13 of 20 Old 12-24-2006, 07:11 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 157
All back to normal! I've lost my overclock but at least I've got my PC back!
post #14 of 20 Old 12-24-2006, 07:35 AM
4.0ghz
johnnys's Avatar
Quoted: 0 Post(s)
Liked: 79
Wtg
johnnys is offline
post #15 of 20 Old 12-24-2006, 07:54 AM
I intend to live forever. So far, so good.
Sin100's Avatar
Quoted: 0 Post(s)
Liked: 106
so it was they motherboard ey, still no idea why the mobo fried? or isnt working?
Sin100 is offline
post #16 of 20 Old 12-24-2006, 10:26 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 157
No idea why it fried but at least I'm back, now I just need to buy a better mobo. I'm running a Foxconn mobo which is crap for o/c
post #17 of 20 Old 12-24-2006, 11:10 AM
Going Broke Overclocking
Quoted: 0 Post(s)
Liked: 1182
Still, I'd give the PS a serious look, check the voltages with the system under full load for about an hour.
Please DO NOT Cite the TOS, simply REPORT and DO NOT REPLY or quote it.
"Life is Learning, Learning is Sharing, Sharing is Life"
"Overclocking is like a drug addiction, the difference is we go broke improving our brain cells instead of destroying them!"
Where in the world to buy on-line
Dual or Multi Partition and Why
Everyone, GET Folding, it is important no matter how much you contribute smile.gif
Phenom II should be called Ph II, not a P II because it isn't an old Intel teaching.gif
The Duke is offline
post #18 of 20 Old 12-25-2006, 09:42 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 157
I was a bit worried about the PSU, I might get a new one and a new mobo.
post #19 of 20 Old 12-25-2006, 10:28 AM
Linux Lobbyist
ThePenguinator.'s Avatar
Quoted: 0 Post(s)
Liked: 64
I have a good feeling it is either your Motherboard, or your powersupply, since I have suffered from having both problem in the past, either bad luck, or parts getting old, I would say those two are the one's I would focus on the most, try and borrow a powersupply from someone, or if that is not possible, go to a computer store, and get them to test it for you.
ThePenguinator. is offline
post #20 of 20 Old 12-25-2006, 10:48 AM
2.4ghz
eagles051387's Avatar
Quoted: 0 Post(s)
Liked: 16
the reason ur mobo probably fried was due to a spike in the electricity. not all surge protectors protect against them and they r undetectable. it is actually worth spending the money on a surge protector or ups that protects against energy spikes.
eagles051387 is offline
