Overclocking using a SATA - Page 2 - Overclock.net
post #11 of 21 Old 01-07-2007, 03:57 PM
4387 point(s) total
Quoted: 0 Post(s)
Liked: 4426
Originally Posted by irvdk View Post
Man, you guys are really tough....gimme a break.
Lets pretend that the thread sould read "OVERCLOCKING WITH A SATA DRIVE"
Yes, that is exactly what I did. WHen I rebooted the machine I got an error NTLDR MISSING.
You can edit the first post and change the topic title?
Check your boot priority. ...and VIA isn't know for overclocking.
To answer most of your questions: (1) a fridge cannot cool a PC (2) 64-bit OS for over 3.4GB (3) If a PCIe card fits, it should work (4) Resolution, not screen size (5) Report, not respond to Spam (6) Single-Rail/Non-Modular PSUs are not always better than Multi-Rail/Modular (7) Sequential does not matter as much as random for OS drives (8) Requirements come before hardware for servers
DuckieHo is offline
post #12 of 21 Old 01-07-2007, 04:02 PM - Thread Starter
333mhz
irvdk's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by OCZedd View Post
Whats your system specs? I had that error before whilst OC'ing and when not OC'ing.
CPU:AMD 3800X2
CPU Cooling: Mini Typhoon/w Artic Silver
Motherboard: A8V-Deluxe Version2.0
Memory:2Gig Matched Pair Corsair XMS3200 W/Heatspreader
Graphics: FX 5500GT
Hard Drive: Dual SATA 80 gig Seagate
DVD Drive: Benq D/L DVD Lightscribe
Power Supply: Ultra 500 Modular
Case: CoolerMaster
Case Cooling: Front 120mm/Rear 90mm
I understand that is what it means, but there is an operating system on the drive. If I unplug it and replug it into the VIA outlet it works fine.
irvdk is offline
post #13 of 21 Old 01-07-2007, 04:05 PM
Multi-Quote King
Quoted: 0 Post(s)
Liked: 845
Fill in your specs so we can help you out easier. If you have a socket 754 mobo with a VIA chipset (as i do),then yes, the SATA will stop functioning after 223MHz.
You will have to use the Promise controller. Put your HDD(s) in and go into BIOS. Where it says "Promise FastTrack Controller," set it to RAID mode. When you boot and the thing is looking for drives on the controller, it will say "Press CTRL+F" or something like that. Do that, and you'll go into the array setup thing. Even if you're only running one drive, you have to set some kind of array up, whether it's 0, 1 or 0+1; just choose any. Then you've got to put the drivers onto a floppy for windows setup (i advise using the Asus MakeDisk program; you should be able to find it in the Drivers folder on the Asus mobo disk). Then you go into windows, press F6 upon setup boot, and in the middle of driver loading, it'll prompt you to insert the floppy for the SATA controller. After that, installation should be as usual.
"I just talk the way I see things... If that's offensive to you... I'm sorry; you're a loser." - Michael Savage
"But you would be amazed by how many people think that the only reason to have a computer is to play games, and that playing games is all that anyone with a computer does." - dangerousHobo
The Hundred Gunner is offline
post #14 of 21 Old 01-07-2007, 04:09 PM - Thread Starter
333mhz
irvdk's Avatar
Quoted: 0 Post(s)
Liked: 0
Thanks,
CPU:AMD 3800X2
Graphics: FX 5500GT
Case: CoolerMaster
So that is different from what is in the directions above?
3. Turn on goto the BIOS ; Advanced > OnBoard Devices Configuration > Onboard Promise Controller [Enabled] > Operating Mode [IDE]
If you are using 2 drives and DO NOT want to use RAID what happens??
irvdk is offline
post #15 of 21 Old 01-07-2007, 04:09 PM
I'm gonna need a sweeper
Fusion Racing's Avatar
Quoted: 0 Post(s)
Liked: 650
as most should know on here, when you overclock with a sata drive, it sometimes messes things up and corrupts windows and whatnot
practically, the solutions are don't overclock, or plug the sata into another port.
for example my gigabyte mobo has 4 sata ports, the top two will mess up when overclocked, but the bottom two are locked and that stops it from happening.
if the psu is hot and producing hot electric then what it is feeding is going to be feed hot electric and there for will be hot.
Fusion Racing is offline
post #16 of 21 Old 01-07-2007, 04:13 PM - Thread Starter
333mhz
irvdk's Avatar
Quoted: 0 Post(s)
Liked: 0
Yeah I'm starting to think it's just not worth it. Can't seem to get a straight answer.
irvdk is offline
post #17 of 21 Old 01-07-2007, 04:19 PM
thealmightyone's Avatar
Quoted: 0 Post(s)
Liked: 181
These are the drivers you want. IDE, not SATA RAID, drivers for the Promise controller.
Taken from this page.
With the correct drivers in hand, follow the process given to you.
thealmightyone is offline
post #18 of 21 Old 01-07-2007, 04:23 PM
With great difficulty
Quoted: 0 Post(s)
Liked: 643
This does
rabidgnome229 is offline
post #19 of 21 Old 01-07-2007, 04:24 PM - Thread Starter
333mhz
irvdk's Avatar
Quoted: 0 Post(s)
Liked: 0
I was not using the one you gave me.. I was using. I'll retry and let you know..Thanks
irvdk is offline
post #20 of 21 Old 01-07-2007, 05:47 PM
Multi-Quote King
Quoted: 0 Post(s)
Liked: 845
Thanks,
CPU:AMD 3800X2
Graphics: FX 5500GT
Case: CoolerMaster
No, you want to use the RAID option for SATA, not IDE. This is whether you're using 2 drives or not, RAID or just one drive. And as i stated in my directions, whether or not you have 2 drives, you have to set up a RAID array. Just choose anything. I've gone through this process and my system is running with it. After hours of headache, this is the only way i've found that it works. Can be some tricky shiz, i know lol
