system temporary freezes? - Overclock.net
post #1 of 7 Old 03-24-2006, 04:45 AM - Thread Starter
333mhz
lilquazyvietboi's Avatar
Quoted: 0 Post(s)
Liked: 0
spec:
amd x2 4200+
MSI neo4 platnium
antec truepower 550w
2x1gb corsair xms
xfx 6800gs
2x WD cavier RE 250gb (RAID 0 500gb)
creative xfi elite pro w/ console
LG mmm... some dvd rw
ZALMAN CNPS7700-CU 120mm (all Cu)... system runs around 35-40C
symptom:
computer keeps on freezing randomly and then unfreezes... sometimes u hear a beep after one of those freezes, and the computer just halt... cant even power off. this happens at random times... sometimes during windows installation... sometimes browsing the web... sometimes... just putting in a disk in the dvdrw.
i have gone through 3 motherboard different changes with different brands, asus, gigabye, now msi. i have used my old hdd, the problem still is there. i have gone through 2 vid card changes... x1600 to 6800gs.
i have gone through numberous test with prime95 (have not failed once), memtest (good also), hardisk scandisk (good), ...
all drivers are uptodate
i wonder what really is the problem?... my dvdrw? cpu? motherboard is defected again? hdd? video card? ...?
it would be nice to have help as soon as possible, because newegg only allow returns no more than 30days ^^
ps: o by the way... i dont overclock hehe... i want this comp to last at least 3 years ^^
lilquazyvietboi is offline
post #2 of 7 Old 03-24-2006, 05:01 AM
4.0ghz
tuchan's Avatar
Quoted: 0 Post(s)
Liked: 329
This is strange, is your power supply OK. Try taking out a stick of ram and see what happens. mmmm I'm thinking..........
tuchan is offline
post #3 of 7 Old 03-24-2006, 05:16 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
it runs on dual channel...
i think ive tried that b4 too
the error happens randomly... sometimes i can go 24hrs straight w/o an error... i've burn numberous 4.7gb dvd and i do alot of rendering and large file converting... i have 1 failed out of many
post #4 of 7 Old 03-24-2006, 07:01 AM
Ooooohh
lightsource's Avatar
Quoted: 0 Post(s)
Liked: 438
I have a few questions for you.
  1. How old are your hard drives? Because right now, I'm looking at your hard drives as the culprit in this problem.
  2. Were all your parts bought with everything intact or did you buy some parts OEM with JUST that part? Becuase there's a chance that (for example) your CPU or Motherboard has physical damage but can't be seen.
  3. What timings are you running your memory at? When I read that your prime95 wasn't passing on memory, I was thinking that you either have a bad set of timings or your memory is bad. This is the 2nd most likely thing.
lightsource is offline
post #5 of 7 Old 03-24-2006, 07:06 AM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
no no... my prime95 things is fine... it runs fine perfectly...... timing is 3-3-3-7
my WD CAVIER RE 250gb x 2 are as new as the other stuff... i bought it all at the same time from newegg.com
all test ran fine... the old hdd i used to test is a fujitsu 15gb... it had problem installing windows too... i got these 2 new drives to work by reformatting + installing windows 10 + times...
everything is retail except for HDD... they are oem ^^
post #6 of 7 Old 03-24-2006, 07:45 AM
Ooooohh
Quoted: 0 Post(s)
Liked: 438
Well as I suspected, you've probably got a problem with your hard drives especially if you had to reinstall windows 10x times. Get those RMA'd.
post #7 of 7 Old 03-24-2006, 07:52 AM
Forum Manager
Quoted: 4 Post(s)
Liked: 1329
Its simply a Drive issue namely the HDD';S or your PSU
Welcome to Overclock
Chimp Challenge 2 x Participant  100 Million+ Folding at Home points  Overclock.net 10 Year Member
ENTERPRISE is offline
