amd cool and quiet is being a problem! - Overclock.net
post #1 of 9 Old 03-28-2006, 10:02 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 5
Send a message via AIM to masterofthepuppets99
ok i want to use amd cool and quiet becaue my 6000 rpm cpu fan is loud lol!
so in the bios i enabled 1.asus q fan2.i enabled amd cool and quiet3.i tried to set acpi 2.0 but it was greyed out so i couldnt set that to 2.0, but it said it was enabled. so then i installed the cool and quiet(latest version) and then i went to the control panel and set power management to minimal or whatever your supposed to do. then i double click cool and quiet and it pops up and shows me my cpu speed and my vcore. my fan speed doesnt change and neither does my cpu speed which i dont want to change.
next question. if i get this to work will it change my cpu speed or vcore. because i dont want it to. i just want a program that lowers my fan speed when im just browsing the web or whatever and then i want it to crank up when i play games or do something cpu intensive.
am i an idiot, should i just buy a 15 dollar fan controller
masterofthepuppets99 is offline
post #2 of 9 Old 03-28-2006, 11:31 AM
CarForum.net
Quoted: 0 Post(s)
Liked: 600
Send a message via AIM to Retrospekt
Downlaod a program called Speedfan, it will let you regulate your speeds.
Originally Posted by Chat
catmmm: my rack would love to play with your rack...
lhowatt: does it fit well on your desk?
catmmm: lhowatt: yeah it fits
catmmm: lhowatt: I kinda have a big desk though
Retrospekt is offline
post #3 of 9 Old 03-28-2006, 11:35 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 33
If you use cool and quiet, you can't OC.
StepsAscend is offline
post #4 of 9 Old 03-28-2006, 11:47 AM
333mhz
Quoted: 0 Post(s)
Liked: 4
Send a message via AIM to Komet Send a message via MSN to Komet
Not true, I'm using C 'n' Q right now. I think what is important is that you reach your maximum OC at your max multiplier. Also, make sure it's Prime95 stable with C 'n' Q on.
Komet is offline
post #5 of 9 Old 03-28-2006, 03:52 PM
Going Broke Overclocking
Quoted: 0 Post(s)
Liked: 1182
I'm seeing more OC with sucess with CnQ
Please DO NOT Cite the TOS, simply REPORT and DO NOT REPLY or quote it.
"Life is Learning, Learning is Sharing, Sharing is Life"
"Overclocking is like a drug addiction, the difference is we go broke improving our brain cells instead of destroying them!"
Where in the world to buy on-line
Dual or Multi Partition and Why
Everyone, GET Folding, it is important no matter how much you contribute smile.gif
Phenom II should be called Ph II, not a P II because it isn't an old Intel teaching.gif
The Duke is offline
post #6 of 9 Old 03-28-2006, 04:52 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 5
ok i chose to use speed fan and how do i change my cpu fan speed
post #7 of 9 Old 03-28-2006, 04:54 PM
back with a mac
Quoted: 0 Post(s)
Liked: 349
Is the CPU fan hooked right on the motherboard? If so, then fan speed 2 should be the one to use to control speed. Set it to 75% and see how it goes. Play with all the fan speed options there.
Coming and Going.
Zipnogg is offline
post #8 of 9 Old 03-28-2006, 05:02 PM
Forum Manager
Quoted: 4 Post(s)
Liked: 1329
It is known that cool and quite can give you problems in an oc becasue i beleive it lowers the multi or something within the AMD cpu's to cool it down thus then it can reduce fan speeds. I would disable cool and quite and get a program like speedfan to regulate your fans.
Welcome to Overclock
ENTERPRISE is online now
post #9 of 9 Old 03-28-2006, 05:22 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 5
t says taht fan1 is my cpu fan but it wont let me change it or i dont know how... and i know this is a bit off topic but what patch is the dual core patch for quake 4
