need help in overclocking - Overclock.net
post #1 of 3 Old 10-12-2013, 06:20 AM - Thread Starter
taeness666's Avatar
Quoted: 0 Post(s)
Liked: 0
i need help in overclocking my fx 8320.. i have a gigabyte 990fxa-ud3 rev 4 mobo, fsp raider 650w psu..deepcool iceblade pro 2 air cooler
BCLK Clock Control 200 mhz
CPU NB Frequency 2200 mhz
HT Link Frequency 2600 mhz
CPU Clock Ratio 20
Extreme Memory Profile profile1
System Memory Multiplier 8.0
Memory Frequency 1600
CPU Vcore normal
Dynamic Vcore(dvid) normal
NB Core normal
Dynamic NB core(nb dvid) normal
Dram Voltage normal
Dram Termination normal
HT Link Voltage auto
NB/PCIe/Pll Voltage auto
CPU PLL Voltage auto
NB Voltage auto
Vcore Loadline Calibration auto
what will i change in order to have a stable overclock? can i reach at least 4.5ghz?
taeness666 is offline
post #2 of 3 Old 11-12-2013, 01:48 PM
PC Gamer
DMatthewStewart's Avatar
Quoted: 0 Post(s)
Liked: 37
Im glad you made this thread because I was just about to ask for the specific settings for all of these as well. Currently there is a guide for overclocking my mobo, but no one has updated it and the main settings it refers to no longer exist.
So, I hope someone sees this. I am replying to bump it and hopefully get it in front of more OC members
DMatthewStewart is offline
post #3 of 3 Old 11-13-2013, 02:51 PM
WizardontheJob's Avatar
Quoted: 1 Post(s)
Liked: 197
Every overclock is like a unique little snow flake. You could have 2 people with the exact same hardware configurations that have to use two completely different set of settings to reach the same overclock.
To do this right, you have a lot of reading ahead of you:
http://www.overclock.net/t/902756/amd-overclock-guide-for-newbs/0_20
To do this fast (not necessarily right) stary by upping the CPU multiplier a notch or to and running stress tests like Prime95. Between bumps I would give Prime95 atleast 15 mins. If you make it without BSODing or dropping cores, bump it a little more. If you are getting errors or bluescreens, try upping the voltage a 100th of a point next.
As a shortcut you can google for something like "8320 990fxa-ud3 overclock settings" and look for people with a similar setup as you and start about 30% below their settings and begin bumping the numbers.
Now, once you overclock you must get stable. Most people will tell you 24 hrs of un-failed Prime95 but I think it's ok after about 5-8hrs.
If you're going to dump on someone's ideas, at least have some good ones of your own.
WizardontheJob is online now
